Freeing a Stuck Clutch Plate
   / Freeing a Stuck Clutch Plate #1
toddwulf
Cameron Park, CA.
1998 New Holland 1920
I'd posted a month ago on my 1920's stuck clutch scenario after having been parked for a month or more. After discussing with my tractor shop, he suggested it was probably rusted plate to flywheel as we didn't have the clutch pedal lock down engaged. the fix was to get the tractor on pavement, get it moving and come to a very hard stop in the hopes of breaking the rust weld. Well, it worked and this little advice saved us perhaps $1200 to break apart the tractor for an unecessary clutch job. The best value here is it reaffirms my confidence in Randy at S&G Equipment in El Dorado, CA. He could have told me to bring it in, done the same thing and charged me up the wazzoo. He didn't - Just gave sage advice that worked. That's what great about small towns and fellow tractor owners. Now I feel guilty about not buying my PHD from him!
   / Freeing a Stuck Clutch Plate #3
</font><font color="blue" class="small">( Now I feel guilty about not buying my PHD from him! )</font>
That's the nice thing about tractors, you can always use one more implement /forums/images/graemlins/grin.gif
Kudos to the guy for not taking all your money.
   / Freeing a Stuck Clutch Plate #4
   / Freeing a Stuck Clutch Plate #5
Your explanation left a bit to the imagination, and I'm not doing too well.
"" <font color="red"> the fix was to get the tractor on pavement, get it moving and come to a very hard stop in the hopes of breaking the rust weld </font> ""
" <font color="red">get it moving </font> " By pushing or pulling with another tractor? Or by starting it in gear (if that is possible)?
So the tractor is moving with or without engine power, and in what gear, or in neutral? I'm guessing here it was in gear, but which one. Guessing a high gear being best.
" <font color="red"> come to a hard stop </font> " By how? using the brakes? If in gear, the tranny would have the differential moving the transmission, so hitting the brakes to stop would probably put the reverse pressure on the clutch to flywheel contact.
Glad its fixed.
Maybe the tractor can be started with the clutch pedal down and then be immediately motoring around in as high a gear as possible (per safety, surroundings, and engine power). By keeping the clutch pedal down, the torque likely will break the rust bond free.
Another plus for HST tranny /forums/images/graemlins/wink.gif
   / Freeing a Stuck Clutch Plate #6
Glad its fixed.
   / Freeing a Stuck Clutch Plate #7
Reminds me of the time when my clutch linkage broke on my '73 Dodge D100. Had to start it in first and get it moving (thank God for a granny gear) then quickly throw it into second and third as needed. Drove it 15 miles to a weld shop for the fix.
Alex
   / Freeing a Stuck Clutch Plate #8
Alex
   / Freeing a Stuck Clutch Plate #9
Randy over at S&G and Brian over at Sierra Tractor are both great folks. I live only a couple miles from Brian's shop; he has driven with me up to the house before to get hoses measurements correct, ect. Not many shops will do that.
   / Freeing a Stuck Clutch Plate #10
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
2013 Ford Escape Multipurpose Vehicle (MPV), VIN # 1FMCU0F77DUB50591 (A51572)
2013 Ford Escape...
