Fresh knot spontaneous releases on small square bales, why?
   / Fresh knot spontaneous releases on small square bales, why? #11
Your knotters are out of adjustment. For the knots to pull apart they are not correctly tensioned to start with. The adjustment is straight forward.
   / Fresh knot spontaneous releases on small square bales, why? #12
If you go to plastic twine, better in my opinion, you'll have to tighten the twine discs down pretty tight because the plastic is sicker than what you have. We had a lot of trouble out here years ago when plastic first came out. Then they found some cheaper stuff that really caused a lot of grief. It was white with a line through it. Worked ok after everything was tightened down real good. If the tension plates are wore with a grove you can build them up with brass or weld them over. Just make sure they are super smooth when you put them back on so you don't burr the twine.
Happy Haying
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A57880)
2014 PETERBILT 384...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55315)
2003 International...
2008 International Bucket Truck (A55973)
2008 International...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
2003 Freightliner FL60 American LaFrance Ambulance (A56858)
2003 Freightliner...
