Friction torque limiter and slip clutch adjustment.
   / Friction torque limiter and slip clutch adjustment. #11
A method of increasing it one small step at a time until it just doesn't, or only rarely slips, is the best IMHO. Once you arrive at a good setting, you can use one of these to easily reset each of the springs to the same place.
-2015a-06-jpg
Measuring the springs is ok but that does not take into account springs that have lost tension or clutch disks that have worn thinner thus reducing tension also.
Running the machine and checking the clutch for heat or lack of it is the only way to zero in on the best setting for a particular HP tractor.
If the clutch is set up for a 50hp tractor and is then installing I on a 30hp tractor a reset is absolutely needed to protect the lower hp tractor.
90cummins
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
2018 FORD F150 XL TRUCK (A51406)
2018 FORD F150 XL...
2012 Chevrolet Cruze Sedan (A53424)
2012 Chevrolet...
1996 International Water Truck with a Caterpillar Engine (A55218)
1996 International...
2018 Caterpillar D5K LGP Crawler Tractor Dozer (A55787)
2018 Caterpillar...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
