Front loader won't lift tractor
   / Front loader won't lift tractor #21
Re: Front loader won\'t lift tractor
Milky?
Maybe you have air in the system. That could explain the weakness in the hydraulics. You might want to cycle the loader to it's limits a few times.. same with the bucket curl.. that helps purge any air.
Air typically gets into the system by shutting off the engine then letting the loader drop down by it's own weight while opening the valve.
I have a friend who sells big equipment who tells me you should always "power down" a loader or any hydraulic implement.. In other words.. drop the bucket using the hydraulics.. not with the engine off using it's own weight.. which draws air into the system.
just a thought.
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
