Front loading not lifting after changing hydraulic hose
   / Front loading not lifting after changing hydraulic hose
Finally got the hoses changed.. still no hydraulics on the front or the back.. they were working before the hoses were changed. there is no pressure building up.. possible the pump went out? or doing something else wrong..
new to this tractor maybe not engaging it right?
:confused:
   / Front loading not lifting after changing hydraulic hose #12
Take another look and determine if the pump is even pumping.
Is the fluid level correct?
Is the pump primed?
If it blew a hose, it was primed and generating volume and pressure.
If the hoses are connected wrong, you will perhaps blow a hose or valve
Can you follow the hose from the pump to either the divider valve , if it has one, or to the FEL? In order to see pressure on a pressure gage, the gage will have to be in a circuit that will generate pressure like a cyl or hyd motor.
If the engine is turning, the pump should be pumping.
Does the hose blow as soon as you start the engine, if it does, check the routing of the hoses.
Try this, remove the end hose going to the FEL, and place in a clean bucket, and start the engine briefly, if you have flow, you can assume that the pump is pumping.
Did you see everything work before you bought the tractor, if so, then it must be something you did.
Thanks for the great info, will do these tests and see what happens may be a few days before can get the time to check it out... will let you know what happens. Thanks Nessie :eek:
PS.. the hoses were busted when the tractor was bought, but did manage to see the bucket lift briefly... urg! thanks Nessie:confused:
   / Front loading not lifting after changing hydraulic hose #15
If the hoses were busted when you got it, perhaps they were on wrong to begin with? Check them against a diagram to see if they are all connected right. Double check any quick connects. Make sure there are no levers stuck.
My brother had the loader off a tractor to rebuild the engine... it took longer than expected and when he finished the engine, it all checked out okay and then he put the loader back on. He got two of the hoses connected wrong and the bucket went full curl and then relief popped. He switched the hoses to the correct way and still has the problem, he will probably need to split the case to figure it out (valves are inside trans on old white tractor).
   / Front loading not lifting after changing hydraulic hose #16
   / Front loading not lifting after changing hydraulic hose #17
Sorry you're having trouble. Does it work now?
One thing to check, if it doesn't, is to see if the hose ends crimped on your new hoses are actually machined out. I know that this sounds weird, but it does happen.
If there's no hole in the middle, then it won't flow oil.
   / Front loading not lifting after changing hydraulic hose #18
I would check the following.
Hose from pump goes to the P port.
The T port routes the cyl expended fluid to tank.
The PB port routes fluid flow to another valve in series.
The work ports connect different for different tractor.
Top of page 2, cyl port connection.
https://www.surpluscenter.com/Instruct/I9-7862-F.pdf
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
2015 Ford F-350 Cab and Chassis Truck (A53422)
2015 Ford F-350...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
