front plate weights, 4040 to 5525?
   / front plate weights, 4040 to 5525? #1
hollowcd
Can anyone tell me if it is possible to transfer my old front plate weights on my 4040 to the front of a new 5525? The brackets look like they are similar in pics but not sure if the weights would work or even if the weight brackets could be switched so they would for sure mount up. They are 100lb weights. Thanks for the info,
hollow
   / front plate weights, 4040 to 5525? #2
As costly as 100# weights are you could have a welding shop make some modifications if needed for very little money.
   / front plate weights, 4040 to 5525? #3
The weights will work. I don't think the brackets will interchange though. Some will fit even though the part numbers are different. The only way to know for sure is to try it.
Thanks guys, tried them out and they actually fit like a glove. Of course Deere wants
$75 for the steel pin that goes in the middle of the support to hold them in place, but working for a machine tool distributor has its advantage. :)
2015 Volvo VNL 64T (A55218)
2015 Volvo VNL 64T...
2000 Ford F-550 Altec AT35-G 35ft Bucket Truck (A55788)
2000 Ford F-550...
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
UNUSED LANDHONOR HPF-11-3000G HYD PALLET FORKS (A54757)
UNUSED LANDHONOR...
230112 (A53422)
230112 (A53422)
2007 JLG SKYPOWER 800AJ TELESCOPIC MANLIFT (A52705)
2007 JLG SKYPOWER...
