With Ag tires;
Front tire: 5.00-15
Rear tire: 9.5-24
O.E.
Hmmm, tough finding rolling circumference for something this small.
Even Firestoneag.com compact tractors doesn't have anything.
Firestone Agricultural Tire Division | Compact Tractor Tires
Doesn't include "Ford", only NH and goes back to TC models.
My previous mention of Goodyearag.com, goes off to the Titan site.
I havn't found their compact tractor tire area (yet).
Anyway, I was going to try and "back into" the front/rear ratio with the assumption that the rolling circumference of a 5.00-15 is 1.05 times that of a 9.5-24.
That would be "desirable" and Ag tires were probably the "design center".
Looking to each side of this... I doubt that it would be higher than 7% or lower than 3%.
FWIW, etc.
EDIT:
Titan info
http://www.titanstore.com/info/4T1335
http://www.titanstore.com/info/48D694
So it looks like 75:126 tire ratio ?
Ummmm, someone check my arithmetic;
IF there is a 5% lead (the unknown IF)
75/1.05 = 71.43
126/71.43 = 1.764
ANOTHER EDIT:
IF you can lay hands on a shop manual you MIGHT be able to find the number of teeth on the final drives.
I don't know where this is done on this particular tractor, i.e. you might have to take a ratio of transfer case output shaft speeds and multiply that by the ratio of differential ratios (yeah, THAT punctuation kinda makes it work).
Front tire: 5.00-15
Rear tire: 9.5-24
O.E.
FWIW, etc.
EDIT:
Titan info
75/1.05 = 71.43
126/71.43 = 1.764
ANOTHER EDIT:
