FRONT SEAL FAILURE
   / FRONT SEAL FAILURE #1
dirtworksequip
Veteran Member
Wheeling, WV
2006 JD 3520 w/cab & 300CX loader. 1995 JD 870 w/440 loader & 8b backhoe.JD 455 w/54" mower deck.
On a past post someone stated that they had their tractor back to the dealer to have the front seals replaced. Twice! They went on to say that they had dug a pond and ran it in water. A freind of mine had his struck in a small creek on his property over the weekend and guess what. Front seal is out. So if you are going to use your 4 wheel drive don't do it in water or you will be doing the wheel seals too.
   / FRONT SEAL FAILURE #3
Yikes!.. what's the point of having 4wd if ya can't use it when needed?!?
Soundguy
   / FRONT SEAL FAILURE #4
Do you guys think the water part is a coincidence or cause and effect? I'd say something happened while trying to get unstuck.
I think if you run in water the mud you stir up acts as an abrasive and damages the seal. My friend was stuck and he was spinning the front in muddy water.Luckily only one side failed.
   / FRONT SEAL FAILURE #6
I would have thought that at least the Asian manufacturers would have that under control what with all the rice paddy tractors the mfg.
   / FRONT SEAL FAILURE #7
If it was merely an abrasion failure.. then my fleet of heavy equipment would -NEVER- be operational.
All my scraper pans, bull dozers, and other ground engaging equipment run every day in dirt, mud, etc. I have equipment running in a sand mine about 20hrs/6days.
I think there were other factors at play.. like a breather that allowed the front sump to fill with water.. etc... otherwise.. I'd never be able to keep shaft seals on my heavy equipment that run in sand all day..
Soundguy
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
CAT 430E BACKHOE LOADER (A50854)
CAT 430E BACKHOE...
Lay-Mor Sweepmaster 400 Broom Sweeper (A49461)
Lay-Mor...
2023 Komatsu WA320-8 Articulated Wheel Loader (A49461)
2023 Komatsu...
2014 FREIGHTLINER CASCADIA (A50854)
2014 FREIGHTLINER...
Chevrolet C8500 Flat Bed with a Moffet Kit (A51039)
Chevrolet C8500...
