Front tires caused axle failure...?
   / Front tires caused axle failure...? #11
I would not leave your tractor in 4wd all the time no matter what. The reason is because it creates a lot of stress in the driveline every time you turn.
When the 4wd is locked in and you turn, the front wheels are traveling different distances in the turn from each other and different than the rears, so you create bind all the time. When you have a loaded bucket and you are turning in 4wd, you are really stressing the system. Plus you can wear the tires a lot faster.
I am not saying that leaving it in 4wd is what caused your trouble, but it didn't help. I would guess having those wide tires stuck all the way out probably stressed the bearings and one thing led to another. Based on what you said your circumference numbers were, I wouldn't think you would be introducing so much lead that you would break the driveline.
For what its worth, I don't ever use my 4wd unless I need it, and then I lock it in and as soon as I don't need, I unlock it. Actually, for what I do, I seldom need it.
I agree. At a minimum, make sure you are not in 4WD if on hard pavement. Most of my travels around my property is on sloped terrain and 4WD is necessary. Going downhill without is dangerous especially if I don't have enough ballast on the backend. Case in point today I took my backhoe off for one job and in the meantime I put a light load of stuff in my FEL bucket and went from hard pavement to a sloped gravel path. I couldn't stop.
Please be cognizant of your surface, slope, and whether you are in two wheel or 4WD especially if you don't have sufficient weight on the back to counterbalance your load.
   / Front tires caused axle failure...? #12
The issue is with the R.C.'s between the front and rear wheels...has nothing to do with the width (how the wheels are mounted)
If the static loaded radii are within an inch and the replacement tires are smaller than stock, tire radius is not the cause of the failure. The difference would decrease the lead ratio slightly which would bring the front/rear drive differences closer to zero than further apart. Tire width and rim offset could easily contribute to early bearing failure.
Bearing failures happen with stock wheels and tires too.
   / Front tires caused axle failure...? #13
How many hours are on the tractor? Did he change the front tires to get the wider tires or did he change them due to having worn out the front tires? But bearings and gears do fail, even in a Kubota. My first Kubota had a gear in the transmission fail while pulling a disk. No shock load, was told just a bad gear, not long after warranty ended.
It's a 1998 with 3250 hours. Previous owner put them on when the old tires were very bald (I have original wheels and bald tires) but also said he put them on because those skinny ones really sink into the soft ground, which I have always had trouble with too.
   / Front tires caused axle failure...? #15
I agree with the above, when needed I use 4x4, once I am going again it's back to 2 wheel.
   / Front tires caused axle failure...? #16
possibly Kubota uses Chinese bearings, or the originals were replaced with Chinese bearings?..
   / Front tires caused axle failure...? #17
Never mind the tires. Did you have proper ballast in the rear?
The way I see it. You NEVER see a tractor sporting a 4x4 Decal. They virtually all are only front wheel "Assist". That front Axle isn't meant to do the heavy work. Have little or no rear ballast and it will be doing most of the heavy work.
And a reason, that I personally would never buy a used loader tractor, because you don't know how it's been used or misused.
   / Front tires caused axle failure...? #18
Yup, same here. Other than wear not needed, my theory is that if I get stuck with 2WD, 4WD will probably get me out. Get stuck with 4WD and you're going to need more......M
   / Front tires caused axle failure...? #19
When I bought my first 4X4 (Dakota) pickup, a friend told me, you drive into a place in 2wd until you can't go anymore, put it in 4wd and back out. In a way, he was right.
I had been using 4x4 most of the time because of the steep hill on my property. My old 2wd tractor would slide down the hill and had no chance going up.
But anyways, is there no consensus non what the true cause could have been? Rolling circumference? Tire width? Tire weight?
My conundrum is that I cannot afford another 4000$ repair to the other side. Nor do I want to spend another $500+ on new front rubber for the original tires, while loosing the benefits the extra wide fronts provide on soft ground.
So if it was a fluke, I'll leave it as is. If not, I'll change it out. I should also add that the previous owner at one time also made a repair to the front axle/driveline. I cannot recall what it was at the moment. It was not the same repair I just made.
PS....Although online the loaded radius of the replacement tires was listed as 17.7, I measured to the center of the rim with a framing square and got 19 1/4......
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A54757)
KNOW BEFORE YOU...
2012 Ram 3500 Crew Cab Flat Bed Truck (A55788)
2012 Ram 3500 Crew...
PALLET OF NYLON SLINGS, METAL TOOLBOX W/ CHAINS (A54757)
PALLET OF NYLON...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A52705)
2018 CATERPILLAR...
