repete
Veteran Member
Verify that your tire sizes are correct and that the pressures are right on. If you have differing pressures than called for then your axle shafts will rotate at different speeds making engagement difficult.
If for instance your pressures in the front axle are low the problem can be increased by a load in the bucket because of the effect of reducing the tire radius.
