Frontier Pallet Forks
   / Frontier Pallet Forks #11
Engine66 said:
1) Does the self-leveleing feature of the FEL interfere with being able to keep the forks tilted holding a load?
Self-Leveling will actually make the forks MUCH easier to use.
With a traditional loader, as you lift the boom up high to load something off of a truck, for example, you have to constantly tweak the curl to keep the load level on the forks. With self-leveling, the forks will stay at the same angle to the ground when you raise or lower the load.
Without self-leveling, forks can actually be a bit dangerous - you can easily dump heavy stuff back on yourself if you are not careful. For example, if you were to be loading a refrigerator into a truck. I always strap bulky stuff like that onto the pallet or tight against the fork frames before lifting.
On dedicated construction forks like a Lull or something, self-leveling is a given.
- Rick
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
3 Point Metal 4ft Cargo Carry (A51573)
3 Point Metal 4ft...
12in Backhoe Bucket (A52748)
12in Backhoe...
2012 PETERBILT 365(INOPERABLE) (A52472)
2012 PETERBILT...
