Frustrated !!!
/ Frustrated !!! #1
Fred Joe
Fordson Dexta
Hi, Ihave a Fordson dexta tractor and the lift cylinder won't hold up.Lift goes up no problem but will not hold.
New seal put in piston and o rings checked can't find problem. Please HELP;)
/ Frustrated !!! #4
On the older tractors, most of them have/had inspection ports on the side of the trans. tunnel. If yours has one, the SOP is to pull the cover off, and inspect it while it's running, and operating the lift up & down with a heavy implement on it. Note: This is an inspection port only, not a "stick my finger inside it while everything is moving" port. So word to the wise, if you stick a finger inside it, you might not get it back out.
But, looking through the port with mirrors and lights, see if you can spot a fluid leak from perhaps the standpipe (if it has one), or from around the piston. I know you changed the ring and seal but maybe the cylinder is worn and is letting excess fluid get by it? Also, have you monitored the hydraulic pressure as it lifts, and then while the implement settles back down?? If the pressure stays up, while the implement settles back down, that will tell you the pump is probably ok. If the pressure goes down with the implement, then the problem is likely in the pump. Good luck.
Solesbee Hydraulic Thumb (A61166)
Solesbee Hydraulic...
UNUSED KJ HD 5'HX5.6'L WIRE MESH (3 PANELS) (A62131)
UNUSED KJ HD...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
New/Unused Landhonor Transfer Pump (A61166)
New/Unused...
Volvo EC330BLC Excavator (A61166)
Volvo EC330BLC...
MASSEY FERGUSON 4607M TRACTOR (A62130)
MASSEY FERGUSON...
