fuel 135 with pekins desiel
   / fuel 135 with pekins desiel #1
stuart50
columbia ms
135 massey feguson
my son ran the tractor out of fuel put more fuel in it and bleed lines tractor runs fine for about 30 min and quits rebleed and insalled new lft pump still runs about 30 min and quits still getting air is it just not bleed good are what thanks for any help
   / fuel 135 with pekins desiel #2
I always had to loosed one one of the injector nuts while cranking to get mine to run. This is somewhat of a pain because I had to take the fuel tank loose and lift it to get to the injector nut.
   / fuel 135 with pekins desiel #3
I has at split my MF150 (same engine), and had to do the same as described above to get it running good again. It took several times to get all cylinders going.
   / fuel 135 with pekins desiel #4
you need to renew the fuel filters, or check them out, also check that the tank filter is OK, if need be take it off and wash it out, there also a filter on the fuel injector pump which may also need a clean.
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
2007 Chrysler 300 Sedan (A50324)
2007 Chrysler 300...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
1996 Lincoln Town Car Sedan (A50324)
1996 Lincoln Town...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2019 INTERNATIONAL...
