fuel consumption Hydro vs Gears?
   / fuel consumption Hydro vs Gears? #11
I do agree that the higher rpm for running the HST isn't as nice as running a gear tractor. But yesterday I had to unstack my pile of round bales as the wind finally killed my bale tarp. I put them all in a row instead. Anyways its fun to do, with the HST I can keep one hand on the steering, one on the loader and zip forward and back with my right foot, so I'm doing 3 things at once. I don't know if an HST tractor is twice as fast as a gear tractor for that kind of work but its fun to do and no clutch slipping.
   / fuel consumption Hydro vs Gears? #12
If everything is equal the hydro tractor will use more fuel because it is turning a pump to drive the tractor. The hydro tractor will be more efficient time wise doing something like loader work so even though it may use a little more fuel more work is being done.
   / fuel consumption Hydro vs Gears? #13
someone with more diesel knowledge than myself can confirm this, but as I recall a diesels fuel consumption is more tied to the load on the engine than RPM. The difference many not be as great as you'd expect.
   / fuel consumption Hydro vs Gears? #14
That is what I thought. I just did not want to say it and be wrong.
   / fuel consumption Hydro vs Gears? #15
If you take a look at a few random nebraska tests, you will see that you are right.
The one for my 4720 shows an almost completely linear relationship with load and fuel, holding the RPM fairly constant. It does drink about .78 GPH though with a 2 HP load at 2600 rpm. HP hours/gal goes up considerably as load increases.
2017 Hino 268 26FT Box Truck (A55788)
2017 Hino 268 26FT...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
2019 Genie GS-3232 32ft Electric Scissor Lift (A55787)
2019 Genie GS-3232...
BUNDLE OF APPROX 9 10" I BEAMS UP TO17' (A54756)
BUNDLE OF APPROX 9...
2022 CATERPILLAR 306CR EXCAVATOR (A51406)
2022 CATERPILLAR...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
