Oil & Fuel Fuel filter water drain
/ Fuel filter water drain #1
repete
Veteran Member
SW Washington
L2550DT IH584-4WD
Has anyone seen a fuel bowl with a water drain for a 2550? I get tired of pulling my filter just to get rid of some water.
Not sure. I use clean filtered fuel but it may be condensation in the tank. There is moisture in Washington...
/ Fuel filter water drain #6
My fuel is ran through this filter before going into the tractor tank.
/ Fuel filter water drain #7
LB if the Revnoo'rs see that you can expect to get raided! Looks like you're makin' shine there.
Triple Sink Table (A60352)
Triple Sink Table...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
TAYLOR POWER SYSTEMS SKIDDED GENERATOR (A60736)
TAYLOR POWER...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2006 FRAC TANK 500BBL WHEELED (A60736)
2006 FRAC TANK...
