Oil & Fuel Fuel leak on Jinma 254
   / Fuel leak on Jinma 254 #11
You can get any parts you need from Tommy at Affordable Tractor Sales in Texas. He's a great guy to do business with and devotes a lot of time to answering questions on the forums.
greg_g said:
Assuming you're only replacing one hard line, the engine should start on the other cylinders. It will run rough briefly as fuel pushes air out of your new line. If you want to accelerate the process, don't tighten the top hex collar all the way down at first. That will permit the air in the new line to escape faster. As soon as you see the bubbles turn into raw fuel, THEN finish tightening the top hex collar.
As far as the replacement line, check here. Each line is has a different part number, so you'll have to be specific when you order a replacement.
//greg//
Alright thanks!!!
Chris
   / Fuel leak on Jinma 254 #14
Before you remove it, have you tried snugging it up a bit ?
Yes I did but they are all very tight!!
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
2021 ASV RT-135 Forestry Posi-Track High Flow Compact Track Loader Skid Steer (A50322)
2021 ASV RT-135...
2016 Ford Taurus AWD Sedan (A50324)
2016 Ford Taurus...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2015 Chevrolet Duramax (A50120)
2015 Chevrolet...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
