Fuel Oil Tank Configuration.
   / Fuel Oil Tank Configuration. #21
A word of caution with a slow delivery system...it is very easy to start doing something else or become distracted while fueling up your equipment. By the time it dawns on you there is 100 gallons of diesel fuel on the floor. Automatic shutoff nozzles only work with pressurized systems.
   / Fuel Oil Tank Configuration. #22
I mention the air pump before, then at least you can leave the drum sitting upright and on the floor if desired. 12 GPM Air Operated Barrel Pump Takes a small amount of air pressure (even a little portable air tank can run it). At 12 GPM, it doesn't take very long to fill up.
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2019 Isuzu NRR Roll Off Truck, VIN # JALE5W169K7901549 (A51572)
2019 Isuzu NRR...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A52577)
2005 INTERNATIONAL...
40ft High Cube Shipping Container (A51573)
40ft High Cube...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
