Fuel Problem Ford 4630
   / Fuel Problem Ford 4630 #21
Actually yes, smoke comes from the solenoid if I give it too many cranks
Then you probably have a bad solenoid or a loose connection on one of the large posts of the solenoid.
When the starter is energized, the poor connection heats up and you lose the connection until it cools. Eventually, it won't connect until you tighten it or replace the solenoid or starter.
   / Fuel Problem Ford 4630 #22
I had a similar issue on the same model. Bad fuel cap would not allow air into the tank. I had cleaned the tank and filter system, replaced the gaskets and seals on the filter system and could not get the pump to bleed.
It seems like you have multiple issues.
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2005 TerraGator 8104 (A55301)
2005 TerraGator...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
FAKE (A52472)
FAKE (A52472)
2017 FREIGHTLINER M2 106 (A53843)
2017 FREIGHTLINER...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
