Gregster613
Platinum Member
- Joined
- Apr 19, 2009
- Messages
- 844
- Tractor
- 273 TYM. 2009 //Yardmachines 7 Speed Shift-on-the-goScotts L2048
Hi all,
I've been reading about different problems that each has had and had been feeling fortunate that nothing much bad has happened to me....Well, it's now my turn!!
Saturday I'd been working the tractor off and on all day; trimming trees, hauling the brush accumulated off, etc., etc. and just as I'm backing it up into the garage to put away - it starts running rough and very irregular, RPM's drop and then go back up, then drop down again, I barely managed to coax her back into the garage before it quits running completely. I'm immediately thinking "Why did I wait so long to change the fuel filter?", Yes, I'm way beyond hours due for that change. I've always gotten good fuel and it ran just fine - so what's the urgent need I think.
Anyhow, that's the first thing I do is change to a new filter. But, no change in performance whatsoever. I start doing a search on here for similar problems and see TYMinColton's saga about his problems/change out of the fuel filter. I start remembering that I don't always hear my fuel pump click like it "usually" does when being started. Yep, it's completely dead in the electrical department. At least I think so; I spent a bunch of time cleaning up connections, etc., etc. and tried to test with a voltmeter but I got zero juice or continuity through it.
So I ordered a new one off of Amazon - FCBB universal 12v 3-5 PSI low pressure gas/diesel fuel pump, $24.99 shipping included. It should be here on Friday the 22nd. So on Saturday I'll bolt it up and see if my guess was right. I like that price far better than $135.00 before shipping from a TYM dealer!!
I also want to buy a spare relay that mounts up by my positive battery post. I don't know the actual name for it and my part number comes up as not found anywhere? I "think" it's the glow plug relay but am not sure... Part # off my current relay = [V23134-J1052-D642, 12v - + 0552] that's info copied right off the relay. I don't understand relays or how they really work and am unsure that mine is bad as being in Ca I don't have problems with cold weather interfering with start ups; my glow plug light on the dash works, my lights all work, so its probably okay but I'd like to have a spare on hand anyhow. So, if anyone out there understands about this relay, could you share with me any trivia per relays? It has (2) slim posts with numbers 85 and 86 underneath them and (2) fat posts, (1) with #87 beneath and (1) with #30 beneath. Do I need to be looking for a relay with exact same #ing or what? I'm a novice with this electrical stuff, so could use a bit of advice.
Thanks all, I'll update as soon as my fuel pump arrives, gets installed and "Hopefully" works. Take care, Greg
