Fuel pump not getting fuel to injectors John Deere 5410
   / Fuel pump not getting fuel to injectors John Deere 5410 #11
Then the problem wouldn't be electrical. You can forget worrying about unplugging wires an harness clips.
Where I would start is with a simple jumper lead with battery power. Do this with the key off. Place two finger tips on the pump cover, then touch and release the jumper to the post on the pump. Do this a few times and see if you can feel and/or hear the unit inside click on and off. Try to establish if that's working or not. Those units aren't prone to failure very often, but you never know. Some have been replaced over the years.
Once past that, then work on the fuel supply possibilities. The 5410 has a rear mounted tank, so gravity flow from the tank should be easy to establish.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
2006 FORD F-150 PICKUP (A54313)
2006 FORD F-150...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2013 FORD F450 XL SUPER DUTY BUCKET TRUCK (A51406)
2013 FORD F450 XL...
backhoe attachment for mini skid steer (A53421)
backhoe attachment...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
