Oil & Fuel Fuel sensor/ gauge leaking fuel
   / Fuel sensor/ gauge leaking fuel #1
Bigjune
Jd 5320
There is fuel leaking from the bottom of my fuel tank from the fuel gauge sensor. Any advice on repair? Is it a seal or whole gauge. Fuel gauge seems to work ok. Just a constant drip along the wires going into the sensor on the tank bottom. (jd5105). Thanks for any help someone can offer.
   / Fuel sensor/ gauge leaking fuel #2
There is a gasket used for the sender will be either a thick rubber or cork material. Is also relativly close to the drain valve so will want to make sure is not traveling from there to sender wires.
Thanks. Will check. Tractor only has 250 hours and garage kept so I am at a loss as to why this occurred. I did notice wires hanging down from sensor so maybe something snagged on it and cracked sensor. Thanks for reply. I am going to check fuel drain before I change gasket.
2016 SHADOW CRUISER (A58214)
2016 SHADOW...
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A52709)
2016 CATERPILLAR...
2007 Yamaha Rhino 660 (A56436)
2007 Yamaha Rhino...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
2020 CATERPILLAR 259D3 SKID STEER (A52709)
2020 CATERPILLAR...
17" Wheel Simulator, Front & Rear w/Hub Cap, Ford F-250 Chrome, 1 Set, Item # RZCMWC-9506 (A59076)
17" Wheel...
