fuel smoke
   / fuel smoke #11
Older diesels will "slobber" when they are cold. Slobbering is passing unburnt fuel out the exhaust in a black slimy mess. Get out and really WORK that tractor for an hour then after an hour of hard work, idle down and throttle up. See if it is better or not.
You may also want to add some fuel additive with "cetane improver". Add enough for 6 points. Higher cetane fuel burns easier. That may help a bit too.
jb
   / fuel smoke
good tip. I will do just that and then report. thx
   / fuel smoke
john bud, your advice was right on. I worked it hard for an hour, breaking up garden. put cardboard in front of radiator, got temp up to 195 F, and 95% of smoke dissappeared! still get black, oily residue inside tip of exhaust. too thin to be all oil, too thick to be all fuel . probably mixture of fuel, oil and soot , or "slobber" , if you will. don't you agree? thanks again for advice. don't freeze up there in 'Wi. we are getting 70 degrees here in 'georgia. garden time.
   / fuel smoke #14
Even that last residue will probably disappear if you continue to work her. There likely is a build up of residue in the exhaust and it will take awhile to burn it out. The solution is to work it like it was intended to be worked. With garden time you should have all the opportunity. Good go.
Mike
   / fuel smoke
Thanks for the advice from Poland!!. I have good friend lives in Latvia. Keeps me updated on events there. again, thank you. will keep working little tractor. cheers.
BUYERS PREMIUM & PAYMENT TERMS (A54313)
BUYERS PREMIUM &...
1268 (A50490)
1268 (A50490)
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
Cattle Gates / Feeder (A53117)
Cattle Gates /...
2006 Nissan Titan Crew Cab Pickup Truck (A53422)
2006 Nissan Titan...
