Fuel Storage signs?
   / Fuel Storage signs? #11
ultrarunner said:
I didn't have a choice... the local Fire Inspector told me it was a compliance issue and I also had to buy the triangle/number hazard label pertaining to Diesel.
Is there an exemption for gallons under a certain amount or do you have to label it no matter how small the amount stored?
Is your diesel inside or outside??
How about home heating oil, do the same rules apply to it as diesel???
   / Fuel Storage signs? #12
LBrown59 said:
*I take this to mean mobile units are exempt from taging /carding labeling etc.Correct?
** Ah! nothin like city enforced burn yer house down.
Yes, as far as the City is concerned...
   / Fuel Storage signs? #13
The Genset is outside in my fenced side yard on a concrete pad and not visable from the street and my neigbor is glad I have it because I told him to feel free to run a cord to his freezer/refrigerator if the power is out.
The summer California had rolling blackouts... I was very popular with my immediate neighbors... I came home one night and found three of my neighbors had plugged into my generator... which isn't a problem and I'm glad to help... since we all look out for each other... I just told them to be aware if they plug in more than the 20amp outlet could handle and the breaker trips... they would all be out of luck.
I have never come across a property with home heating oil anywhere inside the city limits... Over 400,000 people live here... but in 30 years in and around the building industry I never even heard of one in a residence.
Pacific Gas and Electric started at the turn of the century and before that, many homes already had gas lighting fixtures... I still come across homes with the original gas fixtures in tact...
Most pre-war homes in Oakland where built without space heating... other than an ornamental fire place in the living room and many had combination gas/wood fired Wedgewood stoves in the kitchens... I've saved several of them from the scrap heap and they are very well built...
   / Fuel Storage signs? #15
ultrarunner said:
The Genset is outside in my fenced side yard on a concrete pad .
How much diesel does your gen set hold?
Is there no exemption for small amounts stored or must you comply even if you store only a quart or a gallon?
   / Fuel Storage signs? #16
Good question and I will need to find out...
The tank is 60 gallons normally, but I have the required double containment tank so my actual is 30 gallons full.
I'm sure it wouldn't be an issue except for the fact it is a "Permanent Tank" vs. Portable.
Lots of pick-up trucks around here hold more than 30 gallons of fuel... my chevy van holds 34 and my neighbors excursion hold 42 gallons...
   / Fuel Storage signs? #17
ultrarunner said:
Good question and I will need to find out...----__The tank is 60 gallons normally, but I have the required double containment tank so my actual is 30 gallons full.
1*I'm sure it wouldn't be an issue except for the fact it is a Permanent Tank vs. Portable.
2*Lots of pick-up trucks around here hold more than 30 gallons of fuel... my chevy van holds 34 and my neighbors excursion hold 42 gallons...
1* Better get some wheels under it / that'll make it a lot safer
2*Yeah and most of it's the more hazardous gasoline.
2021 Honda TRX 420 4x4 ATV (A50324)
2021 Honda TRX 420...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50323)
Pitts Tri-Axle RGN...
2013 Ford F-250 Animal Control Truck (A50323)
2013 Ford F-250...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
