Oil & Fuel Fuel system, Kubota L2250, Help
   / Fuel system, Kubota L2250, Help #1
miketm42
Hello everyone, I need some help. I want to find how I can clean out my fuel system. Someone put water in my tank, so I drained it and the lines, but it still seams to be in the system or because the water was thiner I may have gotten some of dirt from my filter in the system. This is just a guess on my part. Right now it is running like it can't get out of it's own way, and blowing a fair amount of black smoke.
Thanks, Mike /forums/images/graemlins/confused.gif
   / Fuel system, Kubota L2250, Help #2
Mike,
Remember that water is heavier than diesel fuel so any water you have in your fuel lines might settle out.
Now saying that, you need to empty your fuel tank, blow out all of the fuel liens from the tank to the filter to the injection pump. Look at the owners manual about bleeding the system to get air out. This might apply as well for water entrapment. Replace the fuel /water seperator filter.
Go and get some diesel fuel suplement that has added lubricity and a water disperser in it.
Thanks, I didn't know they made a addative for water. I've done the rest, so alls I can do is hope this will take care of the rest.
Mike
   / Fuel system, Kubota L2250, Help #4
</font><font color="blue" class="small">( Thanks, I didn't know they made a addative for water. I've done the rest, so alls I can do is hope this will take care of the rest.)</font>
As someone mentioned, you need to bleed the system. Anytime you pull the fuel filter, or open the lines for whatever reason, you must get the air out. Your owner's manual should have the procedure. It may be as simple as turning a screw on the site glass at the fuel filter, to having to bleed the injector pump. Good luck and keep us posted. John
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2016 Textron T/A 15 Ton Flatbed Equipment Trailer (A59230)
2016 Textron T/A...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
2006 Mercedes-Benz Unimog 405 4x4 Flatbed Truck (A56858)
2006 Mercedes-Benz...
2022 Transcend Xplor 245RL 30ft. T/A Travel Trailer (A59231)
2022 Transcend...
