Fuel system
/ Fuel system #1
cmracing
Ashland, KY
John Deere 5310, 5525, 2240
Looking for a fuel system diagram for a John Deere 5310. Any help would be appreciated very much. Tractor was running seemed to get weak on power, totally fine at low RPM'S... I started it during cold weather just to let run some and it died after bout 10 minutes like it ran outta fuel, has almost full tank, will not start back.
Thanks
Chris
Chmoore39@gmail.com
/ Fuel system #2
Fuel is froze or gelling. Been there, done that.
Then again, you didn't say what temps it was outside.
/ Fuel system #3
Sounds like you need to get some MELT DOWN and put it into the fuel filter AND the fuel tank. Follow the directions on the bottle.
/ Fuel system #4
Being in Kentucky, i doubt the fuel gelled, but water is a good possibility. Check your fuel filters and drain the bottom of the fuel tank. Had this happen to a case skid steer and it was a collection of water in the fuel filter. replaced the filter and runs great. Also happened on my truck, the water seperator froze and was of course full of water, it ran for a minute and then died. i replaced with a napa water separator filter and no issues since.
/ Fuel system #5
I had this happen - the sediment bowl filled with water and froze into slush. Once I figured it out, simply dumped the contents and let bowl fill with fuel. Trouble resolved.
2015 Honda Accord Sedan (A61574)
2015 Honda Accord...
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
2023 26ft Freedom Trailers Akurate Dynamics T/A Mobile Spray Foam Trailer (A61573)
2023 26ft Freedom...
74" X 49" TAILGATE (A64280)
74" X 49" TAILGATE...
