Fuel
   / Fuel #11
I suppose it's not 'politically correct' to say this, but as a guy (also named Mark) said at a place I used to work when the fourth Mark showed up employed there: "It's beginning to sound like we've got a dog with a speech impediment around here: Mark! Mark! Mark!."
Mark (er, the "no HST, no interest" conferred "King of Ballast" "synthetic nut" just plain nut one...)
   / Fuel #12
Hmmmm, I've never had a problem like that; with other folks having the same name./w3tcompact/icons/wink.gif
Bird
   / Fuel #14
P.S.
I've just been buying my diesel at the Mobil Truck Stop on I-94 from the car pump. I think the color has always been yellow. They give me it for the price of reefer fuel since it is for off-road use. I get very little smoke, only on start up, a puff. I've asked them what their sulfur content is and no one knows.
Am I using the right stuff?
JimBinMI
We boys and our toys!
   / Fuel #15
JimBinMI - The whole "sulphur in fuel" thing is a tempest in a teapot, a non-issue. When the low-sulphur fuel was first mandated, a number of fuel injection pump designs were immediately adversely affected - leaks developed around shaft seals. Most of the problem was incorrectly attributed to the fact that the sulphur was gone. Actually, most of the problem was due to the method of removing the sulphur reducing the lubricity of the fuel and lowering the volatiles content to the point that seals that had absorbed them and expanded now lost them, contracted and started leaking. Most of the leaks would never have occurred if the pumps had never been exposed to high-sulphur fuel to begin with. Although, as I said, the sulphur-removal process itself was initially a factor in reducing the lubricity of the fuel. Sulphur is itself a lubricant of sorts but its effect was always minimal, so its removal was less a factor than the others I've mentioned. The sulphur removal processes now in use do not cause this reduction in lubricity so that problem has been done away with. The volatiles issue has also been compensated for by adding fuel supplements, as has the minimal lubricity value of the removed sulphur itself.
What folks don't often realize is that sulphur is corrosive, so there are benefits to removing it, not only from the publicized environmental benefits, but from an engine length-of-service standpoint. The corrosive nature of sulphur didn't cause major problems in diesels because of diesel fuel's naturally anit-corrosive properties, but low-sulphur gasoline is one of the factors contributing to the longer lifespan of today's gas engines, so it's got to help our beloved diesels, too. (Check the official standing on low-sulphur fuel of any major engine producer, and you'll see what I mean.)
In addition to all of this, there's the environmental issues. Anything we can do to assist the recovery of the environment in the long run is just what we ought to do and any other hurdles that need to be overcome just need to be overcome, period. And it certainly appears that all the negative impacts of low-sulphur fuel have been eliminated.
The real issues that should affect our fuel purchasing nowadays are lack of contamination (for obvious reasons), freshness (for obvious reasons), high turnover (for obvious reasons), low-sulphur (for the reasons mentioned), and cost (how much do you spend on diesel fuel?), in that order. In my opinion, of course. /w3tcompact/icons/smile.gif
Mark
   / Fuel #16
I used to play on a soccer team that had four Jerrys (Gerrys). In soccer, you can't simply shout on the field, you have to use the name of one of your players. You shout: 'Gerry, turn and go.' and half the team turns and goes. We started identifying the Gerry's ethnically--English, Dutch and Irish Gerry. The fourth Gerry was a substitute, and substitutes are just called woolies. I was the league president, and also a wooly.
With this team, I guess there was some beer used as after game fuel. Suppose I have to keep on subject somehow. Again, thanks for the comments, MarkC.
   / Fuel #17
TomG - I'd say your post was very much on-topic, considering your inclusion of beer in it. There is no more important fuel than fuel for the body and mind. /w3tcompact/icons/laugh.gif
Mark
   / Fuel #18
MarkC,
"There is no more important fuel than fuel for the body and mind." Are you sure about this, has Amsoil done a study or what?
I could partially agree with you except that about a year ago I began getting terrible headaches after drinking 12-24 oz., honest...no more than that!
When I woke up the next day, I had a headache that wouldn't go away until 3-4 p.m. Only took me twice, then I gave it up for good! A friend said he also developed an allergy in his late 30's, said I might try other brands but it's not worth it to me.
I do miss it on a hot day though! [sad]
JimBinMI
   / Fuel #19
JimBinMI - Such an allergy would leave me feeling worse than any "smiley face" could portray, too. Definitely [sad].
I've never heard of an allergy to beer. Come to think of it, though, I've heard of allergies to pollens and to yeasts, either of which could cause allergies to beer under some circumstances, I guess. My condolences, Jim. Just goes to show - there's always folks around with bigger problems...
Mark
   / Fuel #20
MarkC,
I've got an uncle who's throat swells shut if he drinks beer!
The guy I was talking to that also had the allergy to beer said it had to do with hops. He said that different companies used different levels of hops but it's not worth it to me to find out!
JimBinMI
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2020 ANTHEM 64T DAY CAB (A54607)
2020 ANTHEM 64T...
UNUSED FUTURE FT13CJ EXCAVATOR (A54756)
UNUSED FUTURE...
Electric Mobility Scooter (A51694)
Electric Mobility...
KUBOTA SVL75-2 SKID STEER (A52705)
KUBOTA SVL75-2...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
