Funnel in fuel tank
   / Funnel in fuel tank #21
I'm new on here, and also a novice at mowing, and cannot find how to post a question, so i will just reply to this question with a question. I dropped a wooden stick that I use to check the fuel level (no gauge on tank) into the tank. Now it is on the bottom of the tank. Should I try to fish it out (I was afraid of removing a sensor), or will it deteriorate over time and mess up the engine?
I would not worry, that's why you have a fuel filter. If it blocks your fuel pickup then you will have to do something.
   / Funnel in fuel tank #22
I have one in my Kioti.... been there for about 6 months. Will be there for life probably.
I tried to grab it after draining the tank and using a telescopic/flex camera with grip....could not see a thing in there... even with a lighted flex camera.
It has not caused any issues.
   / Funnel in fuel tank #23
Try using a wire clothes hanger to fish it out. Cut it to size and put a hook on the end of it.
be careful that you dont mess up the fuel float mechanism doing this.
   / Funnel in fuel tank #25
Those funnels are made of a special low melting point plastic. just drop a match in the tank and it will easily melt and not be a problem.
NO!!! :shocked:
DON'T DO IT!!! :shocked:
It's a joke!
I have a grabber with strong sharp grippies.
   / Funnel in fuel tank #26
I dropped the spout in the BX's fuel tank a while back. Couldn't get it out, so it's still in there. Has not caused any problems yet...
   / Funnel in fuel tank #27
I had a problem with some loose rust flakes in my old JD 1010 gas tank so I thought I would use a flex tool with a magnet on the end, to pickup the loose rust. The flex tool got hung up on something , perhaps a baffle or perhaps the sending unit and would not come out. After many attempts to remove the tool, I cut as much off the flex tool as I could and pushed the remainder into the tank, that was probably 10 years ago and no problem since. I think the loose rust has adhered to the magnet and solved the first problem.
   / Funnel in fuel tank #28
Count me in the club, I dropped my black nozzle into the black fuel tank. I tried all of the above ideas, but no luck. Just mess's with the fuel float and reads empty at times no other problems. Been about a year now.
   / Funnel in fuel tank #29
I know a guy who broke a funnel off in his New Holland while he was putting hydraulic oil in it.
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2021 JOHN DEERE 8R 370 LOT NUMBER 188 (A53084)
2021 JOHN DEERE 8R...
FRONTIER CA2072 LOT NUMBER 41 (A53084)
FRONTIER CA2072...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
2018 FREIGHTLINER COLUMBIA GLIDER TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
