PineRidge
Super Member
If you grasp the round painted ring on the round T87F Honeywell stat and gently pull it towards you it will pop off. The heat anticipator is the sliding scale on the bottom half of the stat. Look on the gas valve on the furnace and write down the amp draw to match it to the thermostat. The settings should be the same. If not gently realign the pointer within the T87F thermostat. The numbers are small and normally marked .4, .6, .8, etc. those are tenths not whole numbers
If the amp draw is already set correctly then you need to look elsewhere for the problem. When this furnace short cycles place your hand on the plenum or furnace bonnet (careful it may be real hot) and let me know if it is lukewarm or too hot to touch when the furnace is acting up..
