N80
Super Member
I use mine most of the time, but I need it most of the time. I turn it off if I'm concerned about the fronts digging up my 'lawn' (ie field of nicely mowed weeds). But, as Roy says, experiment a little. You can tell when you need it and when you don't...with one possible exception. That is going up and down hills. You obviously get better traction but hen the front driveline is engaged, the front wheels get braking whereas with it disengaged you have no front wheel braking. So I keep it engaged when I'm on hills...which is most of the time.
As far as FWD vs MFWD, etc etc, those terms are largely a matter of convention. There is no dictionary of precise terminology for these systems and most names are proprietary and depend on the manufacturer. I use the term 'four wheel drive' to describe my Kubota's drive train. Why? Because that is the term Kubota uses for all of its tractors that have front drivelines. The JD literature uses a number of terms, but Kubota uses '4WD' or 'four wheel drive' almost exclusively. There are '4wd' stickers all over my L4400.
So don't get bogged down in semantics, if you have a CUT or SCUT and you use the term FWD, we all know you are unlikely to be driving this:
