G1800 Hydrostatics failing?
   / G1800 Hydrostatics failing? #1
David_in_SC
SC
1952 Ford 8N
I have a G1800 diesel mower with just over 2600 hours. I bought it at 2500 hours and have put 30 hours per year for the past 4 years. Last spring, after setting for about 3 months, the hystat did not want to move, just wanted to growl. Finally, after a long warmup, she moved away and worked great all summer. I changed all filters and fluid and cleaned the screens at end of 2004 in hopes of avoiding same situation at beginning of this year. Well, it happened. I had good luck with it the first few mows of the year. But tonight, it would not budge in reverse.. Just a loud roar. Loud roar in forward as well, but it would creep. So, I pushed it out of garage in reverse and began to mow in forward. After only a few minutes, began to work as it should in both directions.
I assume the loud roar/whine is pump cavitation? I know this is not a good sign. Is it safe to assume that a rebuild of the hystat drive is in my future? Is this something that the DIY person can do at home? Dealer quoted me about $800 for a reman hystat unit and that seems high, especially if I can do it at home.
What all is involved and where can I buy a rebuild kit?
Thanks in advance for the help.
David in SC
   / G1800 Hydrostatics failing? #2
David in SC, There is an /forums/images/graemlins/smirk.gif-ring seal on the suction tube where it enters the top of the HST assy. Replace it and your problem may disappear. It is item #30 on the attachment.
Thanks Todd. I will give it a try. Thanks for the picture.
David in SC
2025 LandHonor RB-14-72W 72in Rock Bucket Skid Steer Attachment (A49462)
2025 LandHonor...
Glenco Disk Chisel (A50515)
Glenco Disk Chisel...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
Agway AccumuL8 Grabber (A50515)
Agway AccumuL8...
