G1800 Hydrostatics failing?
   / G1800 Hydrostatics failing? #1
David_in_SC
SC
1952 Ford 8N
I have a G1800 diesel mower with just over 2600 hours. I bought it at 2500 hours and have put 30 hours per year for the past 4 years. Last spring, after setting for about 3 months, the hystat did not want to move, just wanted to growl. Finally, after a long warmup, she moved away and worked great all summer. I changed all filters and fluid and cleaned the screens at end of 2004 in hopes of avoiding same situation at beginning of this year. Well, it happened. I had good luck with it the first few mows of the year. But tonight, it would not budge in reverse.. Just a loud roar. Loud roar in forward as well, but it would creep. So, I pushed it out of garage in reverse and began to mow in forward. After only a few minutes, began to work as it should in both directions.
I assume the loud roar/whine is pump cavitation? I know this is not a good sign. Is it safe to assume that a rebuild of the hystat drive is in my future? Is this something that the DIY person can do at home? Dealer quoted me about $800 for a reman hystat unit and that seems high, especially if I can do it at home.
What all is involved and where can I buy a rebuild kit?
Thanks in advance for the help.
David in SC
   / G1800 Hydrostatics failing? #2
David in SC, There is an /forums/images/graemlins/smirk.gif-ring seal on the suction tube where it enters the top of the HST assy. Replace it and your problem may disappear. It is item #30 on the attachment.
Thanks Todd. I will give it a try. Thanks for the picture.
David in SC
2012 WESTERN STAR 4900 (A53843)
2012 WESTERN STAR...
1981 LUFKIN 41 FLATBED (A53843)
1981 LUFKIN 41...
2001 Ford F150 (A50121)
2001 Ford F150...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
RIGID 141 THREADER (A53843)
RIGID 141 THREADER...
GENERATOR (A53843)
GENERATOR (A53843)
