jas67
Platinum Member
There is a G1800 for sale locally with a cracked cylinder head. This model uses the D662 engine (16HP @ 3000 rpm). The G1900 uses the D722. Is the D722 the same, externally as the D662 (just with different bore/stroke)? In other words, can I mount a D722 into the G1800?
What other Kubota Diesel engines will bolt right in?
Also, a few more questions:
Does this model have a rear PTO? If so, is it a normal 540 RPM PTO as found on most compact tractors? Same question for 3-point hitch.
What model snow blowers does this model support? Are these easy to find?
Thank you,
Jay
'80 B7100 w/ FEL & 5" King Kutter Rake.
Thank you,
Jay
