G1900S intermittent starting
   / G1900S intermittent starting #1
txcactusdude
I have a G1900S that will not start intermittently. Today after mowing for about 2 hours I stopped the tractor. I blew it off with the leaf blower to get the grass and dust off. When I went to put it back in the shed it would not start. This same thing happened a couple of weeks ago.
The Stop Solenoid was oscillating open and closed when I went to start the unit and it would not fire. After trying several times I jumped the unit off my car and it fired right up. I tried a couple of more times on the tractor battery and no problems. I just put a new battery in within the last month.
Obviously I have some electrical gremlins. Any advise on where to start looking? How do I check the dynamo to see if it is still charging the battery properly?
Thanks,
Dennis
   / G1900S intermittent starting #2
A 12 volt battery fully charged will have 12.6 volts-2.1 volts per cell.A voltmeter is neded to check the charging voltage of the dynamo-should be about 14 volts.First guess,you have a connection problem somewhere-Good Luck!
Barreto 20RTK 36'' Ride On Trencher (A45336)
Barreto 20RTK 36''...
2019 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A44572)
2019 Chevrolet...
2017 Ford F-250 4x4 Ext. Cab Pickup Truck (A44572)
2017 Ford F-250...
1999 Ford F-450 4x4 Flatbed Sprayer Truck (A44571)
1999 Ford F-450...
2011 Ford F-450 Dump Truck, VIN # 1FDAW4GY2BEB97101 (A44391)
2011 Ford F-450...
2016 International WorkStar 7400 T/A Forestry Grapple Truck (A44571)
2016 International...
