GARAGE FLOOR PAINT
   / GARAGE FLOOR PAINT #11
get a floor sander or put down a paint remover and then clean up the residue with muriatic acid to clean the rest of the cement. It will be a messy job to do, but it is better than spending what it will cost to remove the old floor and then pouring a new floor.
   / GARAGE FLOOR PAINT #12
I may do that dor the interum, but the floor is pretty shot. It was once heated and the pipes have cooroded and froze and broke the heck out of it. I patched it last year with vinal patch, but it still looks terrible.
   / GARAGE FLOOR PAINT #13
Mine's been down about a year now, covering garage floor , still holding up good. My floor was fugly, now a showpiece. I would definitely do it again.
Lots of work to do it right. Good luck if you decide to try.
   / GARAGE FLOOR PAINT #14
I was talking to a paint manufacturer representative this past weekend, and I learned why paint doesn't stick to the garage floor where the tires come in contact with it. He told me that when you enter the garage with the car, that the tires are "hot" and as they cool, they contract and pull the paint from the surface. I believe that this explanation is correct, because I remember my parents home where the only place that the paint was missing on the garage floor was where the tires came to rest on it when the cars were parked over night.
   / GARAGE FLOOR PAINT #15
My Jeep Rubicon has GoodYear MTR's on it. They have BIG tread. Typical mudder type if you can picture it. The peeled it right up and left a tread pattern on the floor. No doubt in my mind that what you say is correct about the contraction.
   / GARAGE FLOOR PAINT #16
I'm not sure how it's done, but I've been in a lot of corporate jet hangars that have beautiful floors. I know it's an epoxy compound, pretty thick, and some I've seen even look like they are clear-coated. Whatever the process, I'm also sure it's pretty expensive. Since landing gear tires get very hot, are under tremendous weight, and have a large surface contact area, the "stuff" on those floors must be pretty rugged. /forums/images/graemlins/cool.gif
   / GARAGE FLOOR PAINT #17
Frank,
I would suggest that you talk to a paint company tech. I did and I am glad I did. I talked with a Sherwin-Williams tech and he even came out to look at the shop and make suggestions. First off there are coatings that will resist the "Hot Tire" problem ... they are used in Industrial applications such as Hangars, Automotive Centers, and so on. The ones that I talked with him about were Epoxy and Urethane. The application of the epoxy coating is one were you needed to watch the humidity closely. If the floor is new there is usually no need to etch the floor with acid. Just use a rotary sander. Like the old floor waxing machines and use 60 or 80 grit mesh and slowly sand the concrete. What you want to do is to break the surface so the coating has something to hold on to. Incidentally, this is how you remove the coating or prepare the floor for a change in color etc,. I don’t want to get into to much detail as every product has a set procedure for surface prep. I would stay away from using acid if at all possible because if you aren’t careful you can cause all the metal in the garage that is not protected to rust. Again, go to a paint company / coating company and get them to have a tech contact you. Then have him come to your site. Then make your selection.
I’m happy with how mine turned out. I installed it myself. I was in a hurry to get the floor protect and our humidity when I wanted to install the coating lead me to a S-W Urethane Based Coating and since I am not going to have a Hot Tire situation in this shop every thing is fine. BTW, you should cover the “control” joints with a flexible joint filler and be sure to get into the method of installing this. I can see my joints but I have to look a little bit and nothing like nuts, screws nails can fall into the crack.
Good luck,
Leo
John Deere 2555 Tractor with Loader (A57453)
John Deere 2555...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56436)
2-Row Peanut...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
New/Unused SD Lanch SDLE20 Mini Excavator (A57453)
New/Unused SD...
2021 Husqvarna YTH18542 42in Riding Mower (A56859)
2021 Husqvarna...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56438)
2019 RAM 5500...
