Chuck52
Veteran Member
Cliff,
I just made my beds one block high. That should give me all the advantage I need for weed and water control, and the blocks can get expensive unless you find a good deal on them. The design makes it pretty easy to add rabbit fencing. Cheap pvc pipe, or whatever you have as supports in the holes, and then run chicken wire around them. You can get fancy and concrete in some pieces of pvc pipe as sockets if you like. You can then do stuff like make arches of pvc pipe and put netting over it for rabbit and bird protection. The design also lends itself to plastic frost protection, etc.
A rabbit fence made of chicken wire around a 4x?? bed would probably also prevent most deer damage. I doubt deer would jump into that narrow a space. The guy I got the idea from stressed making the length a multiple of 16' for ease in using cattle panels. If the bed it 4' wide, that also lets you make 4 trellises out of a cattle panel to span the bed. That is really nice for vining crops and tomato supports.
Chuck
Chuck
