Gas flux core wire
   / Gas flux core wire #11
If I am understanding original posters question , He is looking for a 4 lb. roll . I can't find any of my sources who sell 4 lb. rolls . 2 lb. , 8 lb. , 10 lb. , and even bigger . :confused3:
Fred H.
Well you know what they say about having what you want when you want it. There's just no way 2Lb or 8Lb rolls will ever work if one has their heart set on 4 Lb rolls. I've got an idea. How bout I buy an 8 Lb roll,remove half of it then sell it to op for twice what I paid for 8 Lbs?:hyper:
   / Gas flux core wire #12
The smallest lincoln list for all the dual shield I looked at (71M is what I use) is 10lb spools, since it's mainly used for heavier fabrication and depositing a lot of material quickly i guess they figure anything smaller wouldn't be too desirable.
Is there an application where you need the smaller spool for the welder or are you just looking for a smaller amount for small job or test run?
I don't think it would transfer well to a smaller spool for the lincoln wire if that's what you need (too stiff), some other brands are softer (national brand was real soft but junk, gave away a mostly full spool)
   / Gas flux core wire #13
Alloy Rods, ( ESAB now ) had a 10# Dual Shield 7100 ultra at one time. I never knew anyone else to offer it on that small of a spool. Plus it went down to 035. The schools used it to test the student welders. I also thought I saw a Hobart 71T-1 wire in a 10#. Anything smaller than 10# is likely not out there. Let us know if you do find one.
This little welder can only take 4 or 8 lb spools guess I should of spent a few hundreds more
   / Gas flux core wire #15
So far, I'm not the only one who's NEVER seen a 4 pound spool - are they just an 8 pounder that's half full, or with a bigger "core", or what?? Steve
   / Gas flux core wire #16
None around here. Question answered.
Now as to the question: I have flux core wire for my non-gas welders in 2 and 10# rolls and non flux core wire in the same sizes for my gas MIG. I'm curious as to why you use (or think you need) the additional cleansing of the joint by using flux with gas?
It's a different flux core wire used with gas shielded flux core as opposed to regular flux core and reverse polarity. I had my supplier get me a 10# spool of Lincoln Outershield 71M. I love it.
Google gas shielded flux core and learn it's advantages. Pay particular to Jody at "weldingtipsandtricks".
http://www.lincolnelectric.com/asse...shielded-outershield-outershield71m/c3101.pdf
   / Gas flux core wire #18
I just like duel shield a lot better then intershield.
   / Gas flux core wire #19
Your welder will take 4 or 8" spools. 8" spool holds 10#
2011 Ford E-250 Super Duty Cargo Van (A55852)
2011 Ford E-250...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2010 Ford F150 (A55973)
2010 Ford F150...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
JOHN DEERE CT322 SKID STEER (A52707)
JOHN DEERE CT322...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
