bigdeano
Platinum Member
Electric pumps made for carburetors only put out a few psi, like 3 to 5, should work fine. Kind of a tossup which kind to use.
Look on the bottom of the float bowl to see if it has a solenoid on it. Some small engines are fitted with a fuel shutoff solenoid on the main jet to prevent it from siphoning into the cylinder when the engine is turned off. Had that fail on a B&S engine and kept filling the crankcase full of gas. New carb was as cheap as replacing the solenoid. Also had to change oil twice.
Had my solenoid fail and dump some gas in crankcase, looked up parts and choose to purchase inline fuel shutoff instead for $3. I shut off the fuel when done mowing and turn it on when I get the mower out. Runs fine.
