My life pretty well centers on small engine fuel consumption. I live off grid in Alaska. I live on 12 volts and recharge batteries with a 7 HP mower engine and an alternator. 12 volts and a 30 amp charge rate equals 360 watts, so it takes about 4 hours a day to charge batteries. These engines run about 1GPH or more. Simple math = 120 gallons a month
I said THESE engines, I did not say MY engine, I get 9 to 10 hours on a gallon. I said I live off grid, I didn't say it was my only option. There is power 50 feet from my house. I am off grid because I can make it cheaper than the power company. They charge $35 a month for the meter PLUS electricity. Nothing comes with the meter. Electricity is around double what it is in the lower 48. My fuel bill is a fairly consistent 12 gallons a month.
Sorry people, no big secret here, no conspiracy, hidden wires, hydrogen, no patents, NUTTEN. I even use regular gas.
SHHHHHH here is my secret ............ While there is a bit more involved with the alternator to make it work, the only thing I did was to set it up to run at an idle. People use a 3 hp engine running wide open under a strain to tun an alternator that takes 5 HP. What do you think fuel consumption would be. By using a couple extra HP I can run lower RPM. Here it running, you can hear it idling.
Gasoline generator ruing on propane w/o propane carburetor - YouTube
NOTE: This was an experiment running it on propane. I will get to that in a minute.
That may not help your riding mower much, but if you are thinking of building something or buying a new engine for something, Keep it in mind. Lowering the engine RPM has a HUGE amount to do with fuel consumption.
Now then for the riding mowers and propane, I played around injecting propane into the air cleaner and running the engine on solely propane.
Propane mower with stock carburetor (large file) - YouTube In this situation I got about three times the running time/dollar in fuel savings and I didn't even have a propane carburetor. The difference is that it was running faster. At an idle, I actually get better fuel consumption on gasoline. AT AN IDLE, I got about 25% less running time on propane over gasoline (ON MY GENERATOR).
Hope this helps on fuel consumption
