Gas or Diesel
   / Gas or Diesel #21
Lets assume were living in a town of say 20,000 people, most of these towns have a small engine service, and for a few bucks they can get your rig running if it breaks down, or the regular deal in the spring of the year, trying to get it started.
I drove by a couple of guys today trying to start a lawnmower with a pull cord.
Now lets enter the diesel into the picture, it won't start, so where do you take it, its a pretty good chance the small engine guy isn't going to get it going without knowing about the glow plugs, water separators etc.
Okay where is the nearest dealer or guy that works on diesel garden tractors, more in likely at a dealership. So you make an appointment and trailer it out, but wait just a minute here, is the dealer going to line you right away with his diesel mechanic, maybe he will but its a good chance you will be waiting a while, diesel mechanics aren't right around the corner like these small engine guys.
I have a good sized shop with all the tools and have worked on things with four wheels for 55 years, and two summers ago a friend of mine wanted to bring his 430 John Deere diesel to my place to compare water lines to the x728, anyway he trys to start it to drive it off the trailer and it won't start, so he monkeys around with it for a while and says I think its the whachamacall it, because I've never heard the name he called the part he thought it needed.
We had to push it around and into my shop.
If someone is going to buy a diesel garden tractor they should at least find the different names they call the parts, that might help to try to explain to some one over the phone what it sounds like when you crank it over and it tries to fire.
We never did get it running but I did stretch out my Achilles tendon by pushing it up onto his trailer.
Also I have never had to push my John Deere gas machines around ever.
Rob
   / Gas or Diesel #22
Here's that 430 diesel, its a pretty nice looking tractor, but he couldn't get it running, I took this picture in front of my house.
Rob
   / Gas or Diesel #23
I hope my friend doesn't see this picture, he's a good guy and I wouldn't want him to think I was cutting his tractor down, that isn't my intention, but I have to admit I really like the looks of these 430's hmmm maybe I could get one and put a Kawasaki in it.
Rob
   / Gas or Diesel #24
Rob
I will say that your reasons for not buying a diesel are among the the most ridiculous statements that I've ever heard. Lucky for you this is a free country, or you would be in jail by now:laughing:
   / Gas or Diesel #25
You know I had to respond to all the comments about fuel consumption, repairs etc etc.
First off if you are buying a lawn & garden tractor, that is used for personal use, that cost over $10,000.00, the tiny cost of fuel, ( gas or diesel) shouldn't even be a thought! We are talking about 6 gallons of fuel. I cut 4 acres of grass at my house with a gas X728 twice until I have to refuel. The cost is around $12.00 a cut That is peanuts in comparison to the cost of the machine. If you can afford the machine you can afford the fuel. It's a garden tractor not a 40 ton excavator!
As for repairs my thoughts are the same.
This is a new, top quality, tractor we are talking about which is covered under warranty. I have been buying John Deere for years and have had very little repairs on all my tractors and the repairs that have been performed are minimal in comparison to the cost of the equipment and I use most of them professionally.
A Diesel engine in this size tractor is just a cool option and that is about the size of it. Like I said in my other post if you are ordering the tractor get the diesel. If the dealer has a gas job in stock and you can save a few thousand dollars if you take it off his hands you would be a fool if you did not take it.
You will not regret either one( gas or diesel )
Good Luck.
   / Gas or Diesel #26
Well, it's quit obvious why rubadub couldn't get that 430 diesel running. :rolleyes:
   / Gas or Diesel #27
Good Luck.
Good morning rboss75
Bravo! I couldn't have said better!
   / Gas or Diesel #28
Amen to that.
Glow plugs? Not an issue, easy to change, IF you would ever need to do.
That gas Kawi engine is fuel injected, it has sensors, and circuit boards. If one of those fails, you would be just as stumped as if you were trying to work on a diesel. At that point, either way it's going back to the dealer. The beauty of a diesel engine is you will very likely never have to work on it. Diesel engines are simple by design.
I am a small engine mechanic for a living, and I see people with old fashioned ideas all the time. "Stick with gas, it's easy" That is backwards thinking of a previous era. In this world today, everything should be diesel. The efficiency is too great to ignore. North America is way behind as far as I am concerned. Go to Europe and try to find anything gas powered, good luck. They see how beneficial it is to use diesel engines with incredible MPG and tons of torque to boot. What's not to like?
Whoever said 0.9 Gal/Hr vs 1.1 Gal/HR is out to lunch. Forgive my Canadian math, but my X740 burns about 3 liters per hour, sometimes a little less if it is light work. It isn't even broken in yet with only 23 hours on the clock. My neighbor with an X728 at 230 hours is burning close to 5 liters per hour. His fuel consumption is almost double that of mine. I put in 25 liters of diesel and I can run for 8 - 9 hours straight. He puts in 25 liters of gas and needs more fuel in 5 hours time. It isn't just the cost that begs an argument. Do you want to get gasoline all the time? Do you want to have to keep and fill 5 gas cans? That gets old fast, on your back and your mind.
Now, as rboss75 mentioned, these are just garden tractors. He is correct, if you can afford to spend $10,000 + on a machine to cut your lawn with...you better not be complaining about purchasing fuel. HOWEVER, if you have the chance to choose, why not get the diesel? If you want to talk dollars, don't forget resale value. Resale is very important and a lot of people overlook it. All the dealerships in my area can't keep used X7 diesels to save their lives. The lot IS full of gas powered X7's though, and they sit for months before they sell for bottom dollar to reluctant buyers. At least that is how they work around here.
Sorry to sound like a J.A, but I feel you are being misinformed, and steered away from something that is very good, simply because of old fashioned ideas from some others. If I was any kind of Government authority, I would ban the production of gasoline powered vehicles.
Don't let a diesel engine intimidate you. These small Yanmar engines are built for industrial applications, for a hard life. They are incredibly reliable, there is a 98% chance you will NEVER have to repair anything on, or in these diesel engines.
   / Gas or Diesel #29
Please don't misunderstand what I am saying, x700 series diesels are great machines and so are the gas models but when you get down to the basics, a gas powered x700 will do the same amount of work as its diesel counterpart, do it as long as the diesel for $1000 less in initial costs. To me a $1000 is a lot to pay for a red hat. If you are running a lot of diesel equipment, with access to off the road fuel, it might pay.
   / Gas or Diesel #30
Do the work as long as a diesel? I completely disagree.
You cannot argue that a gasoline engine will last as long as a diesel, because it has been proven time and time again that is not true.
Late last year I seen an older X495 at my dealership being serviced. I was standing there talking to the mechanic working on it, when I noticed the key was on. I seen a lot of digits and was intrigued. I stepped in closer to see the machine had close to 5,000 hours on it. Turns out it was a small landscape company who runs it 11 months of the year, 5 - 7 days a week. It was purchased new years ago and maintained by the dealer. That engine had never been working on internally. It showed the same compression as the specs for a new engine.
You show me a gas engine that has been worked hard in a tractor that has lasted to the 5,000 hour mark.
I used to be a long haul truck driver, and I owned my own rig. When I sold my truck in 2010, my odometer read 1,562,064 KM, or 970,621 miles. The only internal engine work I ever had to perform was when an injector wiring harness rubbed through under the valve covers. This shorted out an injector, causing the engine to run on 5 out of 6 holes. I don't consider that a mechanical failure as it was the wiring harness, and no metal pieces themselves. That truck is still working today, 3 years later, pulling tri-axle gravel trailers grossing 100,000 pounds 5 days a week. No internal engine work has be done yet. The owner is asking for it IMO, because it will fail sometime soon I suspect, but that is his choice.
Now, that is a class 8 diesel engine, designed to last 1,000,000 miles. I don't expect that kind of life out of a small Yanmar 24HP engine. However, I guarantee you, the Yanmar diesel WILL outlast any gas engine in a tractor. Diesel engines are built much tougher than gas engines so that they can handle the violent explosion of compressing diesel and air. Gas engines just ignite fuel in the cylinder, it burns, and moves your piston. In a diesel engine, there is an explosion inside that cylinder, not a fire. That is why diesel engines have such greater torque. When diesels are designed, they are built for abuse, and longevity.
Take it for what you will, I think this is a constructive argument. However, you will never convince me that a gasoline powered X700 series will outlast a diesel powered X700 series as far as engines are concerned. If your a home owner or property owner, and you will never put enough hours on your machine to prove me wrong, than obviously the point is moot. If you ARE going to hour out your machine, that is when I would say my argument stands.
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
2011 GAYLEAN VACUUM 130 BBL VACUUM TRAILER (A55745)
2011 GAYLEAN...
2014 Toyota Corolla Sedan (A55853)
2014 Toyota...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
