Gas or Diesel
   / Gas or Diesel #41
Ahh yes the circular debate,, gas or diesel very similar to another circular debate of gear or hydro,, both usually have the same outcome,,, lots of back and forth, pages of "mines better than yours" and no conclusive data to state one is superior. So the BIG question IS did the OP buy something or did he post this just to get everyones feathers up????????????????????????????
   / Gas or Diesel #42
I've been wondering the same thing:)
Rob
   / Gas or Diesel
Not my intend to ruffle anybody's feathers. Thanks to you all for your opinions and advise. I have not made a decision of yet. I was bound and bend on a X700 series when i started this thread. Since then, sanity has prevailed and I'm also looking at cheaper and lesser mowers. Decided that 18 grand is more then i want to spend, but I'm known to change my mind.
If i was getting a X700, it would be the diesel 4wd.
Priced out a X540 this am. $ 8320 plus tax. About 8k less then the X758. That buys a lot of chrome for my bike. Even buys a 120R engine......
   / Gas or Diesel #44
I had a bid of $9500 for a x740 with 60" 7 iron and ended up spending right at $10k for a x750 with 60" HC deck with Auto Connect.
Impossible to do apples to apples on a 7 vs 5 series but if I back out the Auto connect and down to a 54" deck that puts it at $9500 again
No need for AWD here.
   / Gas or Diesel #45
Diesels and 4wd are more of a "chick magnet". I rest my case.:cool2:
   / Gas or Diesel #46
I only paid 11700.00 for a x739 with brush guard about 2 weeks ago.
   / Gas or Diesel #47
A lot of people fall back on old knowledge that was relevant years ago.
The yesteryear problems of diesel engines are almost completely gone.
Fuel gelling is of no concern in these machines unless you live in northern Alaska at -60. If you live in an area where winter conditions apply, your local fuel is treated before it hits the gas station. There is summer fuel, and winter fuel, all over North America. Winter fuel is, you guessed it, formulated specifically for cold weather operation.
Moisture, again, on these machines, I doubt it would ever become an issue. Your only holding 25 liters of fuel here. We are not talking about 1,000 liters. If you stored your tractor for years without so much as looking at it, with lots of empty space in the fuel tank, sure, you might have a moisture issue. If you burn your fuel on even a remotely regular basis, no worries.
I do not run any additives in my X740, and I likely never will. With the diesel fuel we get today, and considering how small these machines are, additives are dollar bills coming out of the exhaust. Someone mentioned the diesels leave soot on the hood. I have just under 30 hours on my X740, with not one wash done yet. I have absolutely zero soot on my hood where my exhaust comes out underneath. It gives one puff of black at start up, and that is it. They burn clean.
Let us all remember these are 24HP garden tractors, and nothing more. Enjoy your machine, whatever you have, instead of worrying about what may or may not ever happen to it.
   / Gas or Diesel #48
The SMOKEOUT is a NOT a issue with my 2011 JDX740.Little puff of smoke on start up.My 2008 Kioti diesel is another story on startup little smokey.coobie
   / Gas or Diesel #49
I am sure the 10-15 percent ethonol they put in gas is good on your motor also?Do some reading on that.Gas used to stay good for a few months now your lucky if it stays good for 2 weeks unless you use a additive like marine grade stabil or starbrite(goggle that).I have (DIESEL)RTV 900,JD X740,Kioti DK40se and a diesel pickup and have NEVER had any fuel issues.With all due respect(RUBADUB) you posted this same hogwash over at the My tractor forum in the JD garden tractor section and got beat up pretty bad.Just admit you don,t like diesel engines and move on.A parting note to rubadub have you ever owned a diesel truck,tractor?Just curious because you seem to have a lot on knowledge if you have,nt?coobie
   / Gas or Diesel
I am sure the 10-15 percent ethonol they put in gas is good on your motor also?Do some reading on that.Gas used to stay good for a few months now your lucky if it stays good for 2 weeks unless you use a additive like marine grade stabil or starbrite(goggle that).I have (DIESEL)RTV 900,JD X740,Kioti DK40se and a diesel pickup and have NEVER had any fuel issues.With all due respect(RUBADUB) you posted this same hogwash over at the My tractor forum in the JD garden tractor section and got beat up pretty bad.Just admit you don,t like diesel engines and move on.A parting note to rubadub have you ever owned a diesel truck,tractor?Just curious becaues you seem to have a lot on knowledge if you have,nt?coobie
I see you got fancy wheelcaps on the front but not on the back tires. Not available or...? And how much??
2000 INTERNATIONAL 4900 DUMP BODY (A56138)
2000 INTERNATIONAL...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
32 SWIVEL MINI EXCAVATOR BUCKET (A55745)
32 SWIVEL MINI...
2015 Ford F-250 Knapheide Service Truck (A53422)
2015 Ford F-250...
2006 BMW 325i Sedan (A55853)
2006 BMW 325i...
2017 Dodge Charger Sedan (A53424)
2017 Dodge Charger...
