Gas Powered Post Drivers
/ Gas Powered Post Drivers #42
Well, I bit the bullet and ordered a gas powered one over the weekend. I have a bunch of t-poles to set and will also build some more welded pipe fencing, so I thought I'd buy one that claims to be capable of also driving the 2 3/8" pipe posts. I travel quite a bit, so I need to work efficiently when I have time and it makes renting a PITA and not as cost effective. I thought of buying one of the pneumatic pounders like the Rohrer mansaver, but after using one years ago, I didn't think it would be up to the task of driving the 2 3/8" pipe (I used one on t-posts years ago and it worked fine, albeit clunky and not overly powerful)
I ended up buying a Skidril G20D 2-stroke in a three piece kit with a t-post, 2 3/8" and 3" adapter. I chose the 2-stroke over the 4-stroke for a couple of reasons. The 2-stroke was slightly lighter, more powerful and $200 less. Also, when using a quality 2-cycle oil, you get some fuel stabilizing qualities. I've had chainsaws that have sat for extended periods and still fire right up when I pull them out, with some of my 4-strokes, not the same luck.
I looked at the different offerings and decided the Skidril had a great reputation and decent price, compared to the Titan and some other domestic models. I never seriously considered the Chinese knock-offs. I don't need that frustration.
It should arrive next week sometime, apparently they're made to order for the non-commercial customers. I'll give a review when I have a chance to use it.
/ Gas Powered Post Drivers #43
I'm looking forward to hearing how it works out for you. I'm not familiar with that brand. Where did you buy it from?
/ Gas Powered Post Drivers #44
Eddie,
I bought it off a ebay distributor. You can also buy them direct from Skidril, but it was slightly more that way.
I'm interested in seeing how it drives the 2 3/8" in my black clay. It's been so dry, I decided to put my fencing off until we started getting rain and the ground started softening up. Between the rain a few weeks ago and again this week, I might be back on the fencing projects sooner than I expected.
/ Gas Powered Post Drivers #45
Eddie,
Same here - I've got fencing that needs replacement but I'm not confident of driving posts into sun-baked clay... My local rental yard has gas-powered drivers and I'd love feedback as to how well they work before making assumptions about my upcoming task!
/ Gas Powered Post Drivers #46
I just did a quick look for them on ebay and saw that the 2 stroke has a Honda engine. I never heard of that before. Did you get the Honda engine? To me, that's the gold standard of engines and pretty much the only thing that I'll buy anymore.
/ Gas Powered Post Drivers #47
I think the 4 stroke is a Honda. I believe the 2-stroke might be a Tanaka, based on some of the reviews I researched. I've used some Tanaka 2-stroke stuff before and it's been solid. I just got shipment info and it gets delivered tomorrow, so we'll know soon enough.
I bought a Stihl blower/vac a few years ago that was a 4-stroke. What's strange is it still requires a fuel/oil mix and doesn't have a crankcase. It doesn't have near the power of a 2-stroke, although it is a lot quieter.
/ Gas Powered Post Drivers #48
Just rent one when you need it.
Home depot has a nice MTA with a honda engine for about $100/day or $400 per week. You can pound a lot of posts in that time.
Check around - you can rent one that attaches to the front of the tractor or skid steer for about $150/day.
It works great and you don't have to foot the upfront cost or maintain it.
Don't buy a cheap one. The expensive ones are expensive for a reason - they're much better.
/ Gas Powered Post Drivers #49
Is this humor :D Try that at my place and you'll have bent tposts. Too many rocks.
Same here! I have to laugh then videos show someone digging a deep post hole with one of those hand diggers.
I borrowed a 3 point hitch digger to mount on my Massey expecting (hoping) to make easy work of installing 8' PT posts for a garden fence. Hey, at least I got through the sod before it gave up! :rolleyes:
On the plus side at least I got pallets full of nice rocks to use for other purposes.
/ Gas Powered Post Drivers #50
Those 3-pt post hole auger diggers are about worthless if you have any rocks at all. At least with a FEL mounted auger, you can angle around and find the edges or seams between rocks. You definitely need reverse though.
/ Gas Powered Post Drivers #52
An old neighbor claimed the rocks mated and multiplied, kind of like rabbits :D
2006 Toyota Highlander Hybrid SUV (A64557)
2006 Toyota...
(2) 10R17.5 TIRES W/ RIMS (A65055)
(2) 10R17.5 TIRES...
2013 INTERNATIONAL DURASTAR 4400 FORESTRY BKT TRK (A63276)
2013 INTERNATIONAL...
UNUSED PARBREAK BC352-72" HYD BRUSH CUTTER (A65055)
UNUSED PARBREAK...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
2020 VOLVO VNL760 SLEEPER TRUCK (A59914)
2020 VOLVO VNL760...
