Gas vs Diesel Hp vs Torque
   / Gas vs Diesel Hp vs Torque #51
   / Gas vs Diesel Hp vs Torque #52
   / Gas vs Diesel Hp vs Torque #53
orezok said:
Are you SURE about the top end rebuild. 2 strokes don't have a top end to rebuild. Just a headgasket, the head (no valves) and a spark plug!
I think he is talking about the cylinder and piston. They are the "top end" of a 2 cycle. The crank is the "bottom end". That was my AssUption.
jb
jb
i agree, rebuilt the "top end" with a "top end" kit for my cr250's a bunch of times. Thats a 2 stroke dirt bike,lol. Its a piston, gaskets, and bearings. now im riddin a 450f which is a 4 stoke lots more TORQUE and alot easier to ride.
   / Gas vs Diesel Hp vs Torque #55
Yes I'm sure about the 2-stroke top end rebuild, have done it dozens of times.
   / Gas vs Diesel Hp vs Torque #56
Iowachild said:
Here is a good article comparing a 22 HP Kohler Command gas engine with a Kubota 22 HP diesel.
Why Diesel Engines?
One thing to note...
The Kohler 22HP engine makes 22HP with two cylinders and 41 cubic inches of displacement.
The Kubota 22hp engine makes 22HP with three cylinders and 54 cubic inches of displacement.
Thats around 30% larger displacement. Not really a fair comparrison. Find a diesel that is 41 cubic inches and two cylinders and compare the HP and torque charts for a fair camparison (in my humble opinion, of course :)).
   / Gas vs Diesel Hp vs Torque #57
Are you SURE about the top end rebuild. 2 strokes don't have a top end to rebuild. Just a head gasket, the head (no valves) and a spark plug!
There are different top end configurations for two stroke engines. Some have the crank separated from the fuel supply and have regular rings, valves and sparking plugs depending on design plus purging air [ terminology ?? ]
   / Gas vs Diesel Hp vs Torque #58
Moss, Nice to hear from ya!
In reading this thread and following the links in it and the other T vs H threads there was a point made. It was in one of the links, I think. The test procedure for an engine like the Kohler is not the same procedure as for the Kubota. The Kohler is tested with no exhaust or muffler, no air cleaner, no fan and no maybe even load. Someone (in a thread IIRC) said that they can actually "test" by a calculation. Sort of a vertual test if you will.
The Kubota is tested with air cleaner, exhaust, accessories etc. That is a LOT of difference. I would guess that your Kohler is about 15-17 hp if tested in the same manor.
{Ha! Found the link. Diesel vs Gas }
From the link.....
PostAttachment.aspx
The images above are the torque and horsepower curve from a 22hp Kohler Command engine just like is used in a vast majority of consumer and light commercial products. The Kohler engine reaches its peak 22hp at 3600 RPM. However a quick glance at the torque curve shows that its only able to muster a 32 ft lbs of torque at that speed. When put under a light load the engine is unable to maintain its speed and will progressively slow down and loose power. Its torque will peak at 37 ft/lbs @ 2400 RPM where it generates 17Hp, slipping much lower will case it to stall.
PostAttachment.aspx
The Kubota diesel engine shows totally different results when put under load. Just like the gas engine, a diesel has less torque when running at full throttle, however the results under load are not nearly as dramatic. At a full 3600 RPM the engine has about 37 ft lbs of torque, a worst case scenario, but still more than the Kohler can muster under any circumstance. When pushed hard and slowed back to 2400 RPM we are still left with 19.5 Hp and 41 ft lbs of torque. Given the torque difference its going to take much more strain to bring the engine to this point and even more to bring it to its knees. To go back to the wrench example, the diesels wrench does not shorten as quickly when you push on it.
Honesty in Specification
Another issue that is largely ignored is the way in which these engines are ratted. These companies realize that consumers are easily swayed by horsepower ratings and so they do their best to always stay ahead of their competition. Kohler bench tests using the "SAE J1340" standard which has no air cleaner, exhaust, charging, cooling or fuel pump. Once the tractor manufacturer adds on the rest of the components a substantial drop in performance occurs that skews our conclusions seven further. By using Kohler's bench test instead of real world performance the tractor company can make it appear as if they have more power than they really do. This is a very common practice and can be easily spotted on spec sheets where "As ratted by the manufacturer" is in fine print. Kubota used the "SAE J1349" standard which includes standard accessories needed for real world use. We can assume that our engine performance data from Kubota is the same as what we would find in a production tractor. You will also find that Kubota's 22hp engine is actually capable of producing 25hp if its RPM's are further increased. While this would provide good numbers on paper, real world performance would suffer as this engine is commonly used for more demanding tasks (Kubota's own BX2230) where high torque is more important than high horsepower.
So you see, it really isn't a fair comparison. But not the way you thought. The Kohler "cheats" by testing to a different standard. They also don't note if it is continuous or intermittent power in the curve. My guess is intermittent as that is the higher number.
jb
   / Gas vs Diesel Hp vs Torque #59
I read all the data the last time that was posted. I would just like to see the HP and torque curves for two engines with the same number of cylinders and displacement. That's all.:)
In my mind, yes, Kohler tests their engine differently. I agree. They cheat. I agree. But the Kubota engine in that test has 30% greater displacement and one more cylinder than the Kohler in that comparrison. They're "cheating" too. ;)
   / Gas vs Diesel Hp vs Torque #60
jb
OK - differences in terminology, but WHY would you put an hour meter on a racing engine? We rebuilt our engines after every race. Can't remember when we last had a DNF due to engine failure.
City of Lakeland (A51691)
City of Lakeland...
New/Unused Quick Attach Seeder (A54865)
New/Unused Quick...
JARRAFF TREE TRIMMER (A52706)
JARRAFF TREE...
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
