jdrotert
I've been meaning to ask this question to a forum for some time now to get an opinion. What are the pros and cons of using a gasket dressing? I'm talking about paper or cork gaskets here. I will be replacing a water pump on a Ford pickup this week. The pump seals are not leaking, but the paper gasket has failed on the lower side of the pump. I have used 3M westherstrip adhesive before, and it seems to work OK. I've seen aerosol spray versions from Permatex too. I used to work on race cars and the engine builder showed me a tip one night. When replacing a valve cover gasket, he spread 3M weatherstrip adhesive on the gasket and on the valve cover. He waited for both to dry, then stuck them together. This adhesive was like rubber cement. I don't guess it does much for sealing, but I've always done it since.
