Carl_NH
Elite Member
- Joined
- Apr 5, 2002
- Messages
- 3,984
- Location
- Coastal NH
- Tractor
- 01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
It would appear you have enough down wood even if only 30% is not rotted to yield enough decent wood for years, then maybe select cut those live trees that are crooked or not a timber quality to thin out the forest leaving the good trees.
Do you have a BH for your Max? That would make cutting and loading into your dump trailer easy - raise over the bed, cut and let the rounds drop in, or load the log lengths into the dump bed then take home to process.
Do you have an existing / spare chimney flue in the basement? If not - the expense of a insulated flue needs to be factored. Is it a walk out basement, do you have storage near the basement and as others have stated - think about how you will get wood in there - maybe thru bulkhead?
I would also do as DL Meisen says - get a used equipment, a wood stove - $3-500 range, and a used splitter and go for it. But if you need to put in a flue, and make a place to store wood its a lot of $ investment upfront, with not a great ROI, but enjoyment of being active and outside, as Moss Road points out.
