Gathering fallen timber for firewood
   / Gathering fallen timber for firewood #51
Been heating my home with mostly firewood for the past 30 years. I like wood heat but it’s definitely not a money saver in fact I think it winds up being more expensive than LP gas. Then one year the insurance company said they weren’t going to insure homes with wood heat anymore so I had to find a new insurance company but that was pretty easy. I live on 120 acres that’s mostly wooded, but if you figure in all the extra work , equipment and fuel wood heat definitely doesn’t make much sense but I keep doing it. One of my best friends got killed making firewood last spring.
   / Gathering fallen timber for firewood #52
As a kid people were always offering to clean up storm fall oaks on the property... no one has for many years as burning on cold winter nights is not permitted and no wood burning in new construction to the point trying to get laws passed to remove existing by bricking up existing chimneys or remove.
For about a decade you could get paid going to gas but that ship pretty much sailed.
The bottom line is it all depends on local regs.
I shopped for insurance but having a permitted CAT fireplace ended that... simply a deal breaker
As for permits the cost started at $350 to pull and replace a toilet, connect a gas stove, or cut down the old walnut tree grandpa planted 50 years ago...
The new move is to require removal of wood chips...
   / Gathering fallen timber for firewood #53
What location are you talking about here?
   / Gathering fallen timber for firewood #54
You can usually judge the BTU value of wood by its weight, not counting the water in it. Dead and or punky wood usually weighs almost nothing and has similar BTUs. It’s sometimes hard to control in a woodstove as it wants to burn instantly like paper (if dry).
Also, standing dead trees are some of the most dangerous trees you can cut. They are often unpredictable, and subject to snap their holding wood, or be hollow inside and have no holding wood, or have upper limbs that snap and fall and make you late for dinner (aka widow makers).
Agree 100%. Downed wood/timber usually has low firewood quality. Burning rotten wood does nobody or the environment any favors. Plenty of good wood to help manage the forest by thinning, saw log harvesting or clearing to consider. Heat with wood you want good fuel.
Have watched a huge red mulberry die in my front yard for decades. Planted or left centuries ago around the pioneer homestead. Dead 15 years ago, 4’ at base still some limbs 50-60’. Poison ivy and Virginia creeper vines cover most of it. It is a wildlife magnet. Preferred perch for hawks and owls. Pileated wood peckers use the dead limbs as sounding boards for their mating territory. Hummingbirds nest in it. Flocks of turkeys have roosted overnight. Home to raccoons and squirrels in the hollows. Always puts on a good show. My point is dead trees play a vital role in forest health. There are better options for firewood.
   / Gathering fallen timber for firewood #55
SF Bay Area... but Olympia WA also has started with no burn periods and stringent wood stove requirements.
   / Gathering fallen timber for firewood #56
I am glad there are still places you don’t need a permit to install a light circuit or a toilet.
   / Gathering fallen timber for firewood #57
One year, it got Dow to 37 below F in Adams county WI. in February. I was ready. It was 78 in the cabin. I had no furnace. Here’s a great passage from the book, A Sand County Almanac by Aldo Leopoldo.
“There are two spiritual dangers of not owning a farm. One is the danger of supposing that breakfast comes from the grocery, and the other that heat comes from the furnace. To avoid the first danger, one should plant a garden, preferably where there is no grocer to confuse the issue. To avoid the second, he should lay a split of good oak on the andirons, preferably where there is no furnace, and let it warm his shins while a February blizzard tosses the trees outside. If one has cut, split, hauled, and piled his own good oak, and let his mind work the while, he will remember much about where the heat comes from, and with a wealth of detail denied to those who spend the weekend in town astride a radiator.”
   / Gathering fallen timber for firewood #58
We moved in our house on New Year's Day, 1985. It was 69 degrees for a high. Three weeks later, it hit -21, a record here in East TN. We were heating with a fireplace, and I had almost no wood cut ahead. Resolved THAT would never happen again, and since then, I've kept at least a year ahead cut. Last few years, I've keep 2-3 years ahead (4-6 cords/yr)
As soon as I move the contents of one of my four 4 cord sheds to the basement, I begin refilling for 2-3 winters out.
Sheds under construction: (Just barely slide out the 12' x10' roll up door in the shop)
enhance
Roof and hose 'em down with paint out in the driveway:
enhance
Drag to various locations around the farm, and fill:
enhance
enhance
4 cords in the basement:
enhance
Wow, lots of great info and advice and I really appreciate it!
Equipment...
I do have a good chainsaw. For years I had used my Dad's old Poulan and was finally fed up with it and bought a new Stihl last summer. I've learned to sharpen it a lot better over the past year freehand, but the Stihl 2 in 1 easy file makes it a breeze. I still like to be able to do it well free hand though.
I figured a grapple would make light work of some things but I have considered just adding a thumb to the backhoe first before going all out for the grapple. I hadn't considered just dragging logs to a landing to cut to length or trailer home. That would be a good option.
My brother in law has a splitter that I could borrow if needed to get started, but I would prefer to eventually have my own.
I know a guy that does furnace and AC work that I could have set up an indoor wood stove or outdoor furnace if it had to be done 'professionally'. I was leaning towards an indoor woodstove mainly because of price, but I would have to check on insurance issues and it does concern me a little with the flu stack and so on. I wouldn't mind the outdoor furnace. I am constantly taking my dog out in the same area that I would place one, and the firewood, so that wouldn't bother me any. I'm used to it. It is more of an investment but may be worth it in the long run.
My basement is not finished at all, and no insulation on the walls. Just sealed and painted block wall and concrete floor. Not finished, but kept clean. It is all open floor with a man door, and a 7 x 9 utility door on one end. Can't call it a garage door or section off a garage area without getting into insurance issues due the house being overhead. We have a double wide on the foundation. It has the typical insulation on the under side, which is basically the ceiling for the basement. Even a kerosene or wall mount gas heater keeps the basement at around 60° on the coldest nights and it definitely keeps the house level furnace from running quite a bit. My oil heat tank is in the basement also,, which im sure any wood stove would have to be x feet away from it for safety and insurance reasons. Again,, maybe the outdoor furnace would be the better option. I've never looked in to insulation for the walls but that makes sense to be the best place to start to aid with any additional heat source.
The woods... it is on a mountain side. There are a few relatively level areas but 80% of it is not flat. The only good thing would be it is all downhill to get back to the truck. Easy dragging, hauling etc. I could access the majority of it with the tractor pretty safely though, other than a few really rocky spots. I'm glad several folks brought up the fact of dead fallen trees being important to replenishing the soil and homes for critters, hadn't thought of that. Obviously a lot of the already downed trees wouldn't be good for firewood, they've been down too long. But if I would start snagging some as they fall, especially the ones fall over trails, and using them for free firewood rather than go to waste. I don’t think all the more I would use or need would impact the woods too much. And that is the plan, to utilize this wood rather than just toss it to the side. Also glad that folks mentioned about the time frame for firewood to dry. It sounds like if I started anything this winter or spring it may be good for next winter.
You folks have given me a ton of info and advice to consider already and I'm very grateful. This is yet another thing that I can put my little tractor to work with. Any seat time on the tractor is time well spent. I'm anxious to learn more about my options and it looks like there is a wealth of experience and info to go over here. I'll probably contact the heating and AC guy that I know and get some specs and have him evaluate my specific situation before diving into anything. Glad I finally have some direction though.
   / Gathering fallen timber for firewood #60
Any problems with bugs in the wood while storing in your house?
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
Kubota ZG222 (A60462)
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
2016 Lincoln Navigator SUV (A59231)
2016 Lincoln...
2013 Frieghtliner with Altec Bucket Model LR760 (A56438)
2013 Frieghtliner...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
