Gator 825i won't start and bed lift won't work
   / Gator 825i won't start and bed lift won't work #1
treefarmerguy
Kubota 5030
My Gator won't start. It turns over and tries to start but that's all. It did start momentarily but then stopped. Also, the power lift for the bed won't operate so I can't access the engine etc. Both turn signal dash lights light up even though I don't have turn signals! I've checked all the fuses I can find and used a booster while trying to start it. A maintenance light lights but I'm not sure what to check.
Thanks in advance!
   / Gator 825i won't start and bed lift won't work #2
Friend of mine has one of these, and there was a loose connector under the hood that caused similar issue. Cannot remember if it was no crank at all, or just no start.
   / Gator 825i won't start and bed lift won't work #3
Is fuel pump working?
Will check that and the fuel filter if it ever stops raining here in MA.
Thanks, Trails2004.
Any updates?
Problem solved. Before I started taking things apart I decided to replace the battery as it was rather weak and I had to use a jump pack. Installed the new one and it started right up and everything worked! I don't know why the old battery and a 100 amp charger/starter wouldn't start it but I'm a happy guy again. Only have to replace the the problematic clutch now.
   / Gator 825i won't start and bed lift won't work #7
JD Clutch Doc can help with hard to shift into and out of gear issues.
More information please email info@jdclutchdoc.com
BRAKE DRUM HANDLER (A55745)
BRAKE DRUM HANDLER...
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
2005 Mitsubishi Lancer ES Sedan (A54815)
2005 Mitsubishi...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
MAYTAG ATLANTIS WASHER & DRYER (A54757)
MAYTAG ATLANTIS...
Power Horse 7000 Generator (A54865)
Power Horse 7000...
