Gator blades... again
   / Gator blades... again #11
I mean 1/2" blade drop and not 1"
I appreciate the leads, I will see if I can track them down by blade measurements. If not I'll take Barnboy up on the bushings offer. thanks all /forums/images/graemlins/smile.gif
   / Gator blades... again #14
I see mention of blade part # 91-438 noted on page 16 here:
Oregon blades
The center hole is 1 1/8, but the bushings mentioned on page 7 are 1 inch:
bushings
Anyone know of other bushing locations, or do we need to start making a bunch of them?
Can anyone verify the blade part# compatability for a 60 MMM on the BX series?
Chad
   / Gator blades... again #15
You can go to TSC and get their cat 1 to cat 2 bushing, 1-1/8" od X 7/8" id and cut them to just under a 1/4". I cut them with a 4-1/2" grinder and cut off wheel.
   / Gator blades... again #16
I can verify that part #90-987 that I have on my BX 60" deck works better than stock. It's the same thickness, has the same blade drop as stock, but it's .060" longer (.030" per side), however there's enough clearance that it doesn't touch anything.
I did notice one other advantage. It keeps the deck clean, there is virtually no grass build up.
   / Gator blades... again #17
Listed are two blades for a J. D. (91-394 and 90-734)
The measurements appear correct, including the center hole. What about the blade drop?
I am interested in the Mulcher Magnum.
Page 146 here:
Blades
   / Gator blades... again #18
In the picture it looks like a flat blade compared to the Kubota blade with the drop pictured on pg 16. Best way is to call or email Oregon.
   / Gator blades... again #19
</font><font color="blue" class="small">( I can verify that part #90-987 that I have on my BX 60" deck works better than stock. It's the same thickness, has the same blade drop as stock, but it's .060" longer (.030" per side), however there's enough clearance that it doesn't touch anything. )</font>
Can you post the model number of your deck?
   / Gator blades... again #20
The model number for the 60" MMM for the BX is RCK60B-22BX.
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
2010 Honda Insight Hatchback Sedan (A55758)
2010 Honda Insight...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
2012 Ford F-550 Enclosed Service Truck (A55788)
2012 Ford F-550...
(50) Rectangular Pressure Treated Wood Post (A53316)
(50) Rectangular...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
