gauge wheels/dethatcher/"twig catcher"
   / gauge wheels/dethatcher/"twig catcher"
Thanks for the pics. That is an unusual set up, cool!
   / gauge wheels/dethatcher/"twig catcher" #12
Nice fab job Island. Do the lower pins slide along the tubing? Slick setup. It must weigh a ton with that 1" plate (it looks like). Very beefy. What else do you run on front with it?
I wish my fabrication skills were that good. Actually I got it from my dealer (Wallace Tractor). Yes the lower pins slide along the tubing. It doesn't weigh "a ton" but I would guess it does weigh between 100-150lbs or so. The weight is not really an issue as you are not going to use it with a bucket or any other implement to lift things so you just need to be able to lift the attached implement.
I haven't put anything else on it yet. I don't see it as appropriate for a box blade as the strain on the FEL would be too great. It would work very well I think with a back blade however especially in snow plow mode. It would also work with a hydraulic auger/post hole digger.
   / gauge wheels/dethatcher/"twig catcher" #13
The weight isn't as much as I guesstimated. That's not bad at all.
159115 (A60430)
159115 (A60430)
2018 KOMATSU WA320-8 WHEEL LOADER (A60429)
2018 KOMATSU...
(INOP) JOHN DEERE 544 AA WHEEL LOADER (A60430)
(INOP) JOHN DEERE...
Commercial truck Frame with Axle (A59230)
Commercial truck...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
