GC 2300 dying out
   / GC 2300 dying out #1
gator3
I have a GC 2300 with the Iseki 2.9L. It sometimes will run for hours and then start dying. If I back off the throttle to idle it will not die, it will resume idle and I can throttle back up. Sometimes it just will die just sitting there idling. When it dies it starts by losing RPM's gradually, not like you shut off the key. I checked all the saftey switches, they seem to do fine. It seems like there is a small piece of debris floating around in the injector pump because of the unusal pattern. I have flushed the tank and lines, relaced fuel filter. I took the electric lift pump off from under the floor board and ran it with some diesel and it flows fine, plus I can hear it run while in the tractor.
Is there anyone that has had this problem in the past? I did a serch and could not find anything. Thanks in advance for any advice.
gator3
   / GC 2300 dying out #2
Check for poor or loose ground wire
   / GC 2300 dying out
Thanks jeepcj7 I will check the grounds.
Does anyone have a wiring diagram for this tractor?
   / GC 2300 dying out #4
If your tractor dies out by losing rpm's is starving for fuel or has an air leak between fuel tank and injector pump. Check to see if your fuel filter housing has a good seal on the top. An electrial problem will tractor to cut off quickly.
tom
   / GC 2300 dying out
devon lane I think you are spot on. I checked all grounds and all seem to be in great shape.
Yesterday I could mow about 300yds then it would start dying out, but if I kick out the PTO and put it back to idle it will usaully gather itself back up.
It is like there is something floating around in pump or somewhere that gets caught up during high RPMs and when I go back to idle it floats away and allows fuel.
I am wondering if the electric lift pump may be going bad. MF wants 172.00 for that part. I had it out and tested it and it seemed to pump fine.
I do not see any wet spots in the fuel lines as to indicate a hole in the line as to air entering.
But that is what it acts like. Maybe I will replace all the fuel lineand see if that makes a difference. Thanks for all the replys and please keep them cooming in so I can back to work.
   / GC 2300 dying out #6
Do you use any Bio diesel? Sometimes it gells up easily Check your fuel filter again is it a oem part? A good fuel filter will also stop flow if there is any trace of water in fuel.
   / GC 2300 dying out
Don't use bio-diesel. I completely drained and flushed fuel system. Think I am going to replace lift pump and see if that helps. Used vaccum pump to check for leaks, and didn't find anything all this just happened all at once.
   / GC 2300 dying out
I finally found the problem.
I started removing all the fuel line and removed the filter/shutoff bowl. Tried to blow thru inlet and outlet and the inlet had resistence, I took apart the shutoff valve and there was some sort of black garbage.
Cleaned and replaced filled tank back up and off I went. No problems as of yet.
Thanks to everyone for their help.
gator3:)
   / GC 2300 dying out #9
Had a similar problem on our GC2310. Found out the seat safety switch went bad. Bypassed it and works fine.
1604 (A57192)
1604 (A57192)
IRGC80 Lifted Electric Golf Cart **Unassembled**(New/Unused) Plugs into standard 110 outlet , Com... (A59225)
IRGC80 Lifted...
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
2019 Ford F-750 Reel Flatbed Truck (A56858)
2019 Ford F-750...
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
1987 International S1900 Fuel Truck (A55272)
1987 International...
