GC 2300 thermostat temp
   / GC 2300 thermostat temp #1
massey driver
north of winnipeg canada
massey 175,1655 BX 2370-1
Been wondering if anyone has installed a higher temp thermostat into there GC tractor.The one that it has now is 160 o F. Now because of having a cab and a heater in the cab I would like to install a 195 o F thermostat for winter use.Our weather in the winter is say -25 c usually. What I had to do last winter was put a piece of cardboard with a 4" hole in the center of it.It was enough to bring the temp guage up to 160 untill I turned the heater on then the temp would drop[guess the heater acts as a rad as well] Anyway been wondering if it would hurt to put in a higher temp thermostat to get more heat from the heater.I know that they have a special offset thermostat because of the sensor that goes into the housing,but because of me having changed mine to a actual temp gauge instead of the [idiot light] I can put in a regular thermostat.My question is would running it at a higher temp do it any harm. Larry
   / GC 2300 thermostat temp #2
I would suggest not increasing the T stat to a 195 on an IDI engine I would block part of the radiator to get the temp up. They put 160 thermostats in in-direct fuel injected diesel engines because there is a chance that if you load the engine before the thermostat opens you can over temp the pre-chambers and crack the head.
   / GC 2300 thermostat temp #3
I second Labrat's suggestion- partial cover over the radiator. Experiment with cardboard.
Anybody remember the little "window-shade" cover that could be pulled up to cover the grille opening on old 3-cylinder 2-stroke SAABs? Same deal- when car was up to temp and you turned on the heater, the temp gauge would plummet immediately! It really needed that window shade to be closed in the winter.:laughing: There was a little cord with a knob on it located under the dash that you'd pull-- no kidding!
   / GC 2300 thermostat temp #4
That's funny. I bet it worked perfect though.
As silly as it would be in 2010, wouldn't it be nice if things were kept that simple? Today there would be a temp switch, relay, some fuses, an electric actuator, all kinds of crap to fail. You probably couldn't find it under the hood anyway.
   / GC 2300 thermostat temp #5
A 195 T-stat or blocking the radiator both raises the engine temperature. I would go with blocking the radiator as it allows for adjustment, where a 195 T-stat locks you into one fixed temperature. I think a 195 T-stat is too hot, 175-180 would be the max. how does the coolant temp run in the summer while brush hogging?
   / GC 2300 thermostat temp #6
I replaced the belt driven fan with a Spal electeric fan and PWM controller so I can adjust when the fan comes on. I have it come on at 165 in the summer and 185 in the winter and I still get coolant flow through the cylinder head at 160. The PWM makes it variable speed giving it better control... This is an old pic I started with an 11 inch fan but have since changed to a 14.
Thanks for all the replies.I ended up putting a 180 in for the winter.I will reinstall the 160 for summer.I'll soon find out if the thermostat itself will be good enough.I;ve used the tractor have put 5hrs on since the change and it's been running 175 on the temp gauge,before it was showing 160.Larry
   / GC 2300 thermostat temp #8
There is NO rereason to change the thermosyay, as their is a bypass lne on the t-stat housing, so some coolant will bypass, and it will heat up quick.
df.
   / GC 2300 thermostat temp #9
My 1962 Volvo had one too. You had to come to a complete stop to lower it but it sure kept the interior toasty.
   / GC 2300 thermostat temp #10
Didn't realize Volvo had one, too... those Swedes were on to something, I think!:thumbsup:
The SAABs I was referring to were of the same vintage; I had the good fortune to drive a couple, both '65 models, their model number 96, I believe. Very simple, economical, spacious cars that cornered like they were on rails and outdrove evrything but 4-wheel drives (and even some of them!) in the snow. They even had windshield washers when US manufacturuers were just beginning to think about them. Granted, they were 2-strokes....
Kinda homely, but they had a tendency to grow on ya!
I think it's a shame that SAAB and Volvo (and MB, and Peugeot, etc.) seem to have lost the ability to make relatively un-fancy, economical automobiles.
OK. Off my soapbox now....:ashamed:
MCELROY COOL PACK 20 (A55745)
MCELROY COOL PACK...
Mini-Excavator Forks (New/Unused) (A59225)
Mini-Excavator...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58017)
2017 FREIGHTLINER...
6.25 In Heavy Duty Mini-Excavator Bucket (New/Unused) (A59225)
6.25 In Heavy Duty...
22 In Heavy Duty Mini-Excavator Bucket (New/Unused) (A59225)
22 In Heavy Duty...
New/Unused IRGC40 Mini Golf Cart (A57453)
New/Unused IRGC40...
